Looking to Identify exactely what "This" is
Results 1 to 11 of 11
    Jan 2008
    chicago
    10
    Smile Looking to Identify exactely what "This" is
    I have this sitting around for ages, but dont have any idea what it is..came with some collets I purchased_dsc2782.jpg_dsc2781.jpg
    Apr 2020
    1,118
    1026
    389
    Is it a Small 3 jaw chuck without the top jaws?. Similar to the 50-3-2.5 BC model
    Feb 2011
    BFE Nevada/San Marcos Tx
    2,811
    2888
    1787
    WAG, some type of shaft clutch.
    Oct 2010
    Oregon
    5,675
    5501
    2153
    If you push and pull on the threaded end, do the three things that look like chuck master jaws move out from and in to the center? The amount of motion would be small, like roughly 0.020". If so, this is just a piece of an air- or hydraulic-operated chuck. An actuator screws into the threaded end, routed through the spindle hole. (Probably) serrated master jaws would mount to the things that look like master jaws, then actual jaws would mount to those serrated master jaws. But there's several pieces missing from this, if that's what it is.
  5. Likes digger doug liked this post
    Oct 2010
    Dewees Texas
    3,105
    33
    1022
    Have you looked under the crud for lettering or logos? Might be clues there.
    Oct 2017
    1,266
    395
    435
    Is that a 1/2-20 thread in there?
    May 2002
    South Central PA
    14,581
    2818
    4314
    Looks like a diaphragm chuck.
  9. Likes sfriedberg, digger doug liked this post
  10. #8
    Nov 2007
    marysville ohio
    10,610
    2970
    7323
    I think it needs more dust!
  11. #9
    Oct 2017
    1,266
    395
    435
    Quote Originally Posted by Mud View Post
    If the threads are 1/2-20 then it will fit on a drill.
  12. #10
    Oct 2010
    Oregon
    5,675
    5501
    2153
    Mounting this on a drill would be silly if the threaded end is intended to open/close the jaws. If this is what we think it is, the body is what's mounted to the spindle, and the threaded end is pulled to close the jaws. If you just screwed the threaded end to a drill spindle, the chuck wouldn't grab anything.
  13. Likes digger doug liked this post
  14. #11
    Oct 2017
    1,266
    395
    435
    Quote Originally Posted by sfriedberg View Post
    If mounted to a drill, you just pull the chuck body back. Besides, silly things exist and have a purpose. I've chucked all sorts of weird things in a drill to twist or wind wires, polish or chamfer parts, drive handwheels of machinery, test clutch engagement, drive large taps and oversized tooling, etc.
    It seems totally reasonable to want to chuck a lot of the same diameter part in a drill quickly and repeatedly. Maybe to save on an additional facing/deburring machine cycle on the back side of a turned part, for example.
