Looking for that "micro mesh chip pan liner someone had fabricated
Results 1 to 17 of 17
    Sep 2007
    Washington
    5,333
    209
    1639
    Default Looking for that "micro mesh chip pan liner someone had fabricated
    Hi guys,
    Awhile ago (might have been a year or more), someone had posted some pictures and tech info on a chip pan insert they had made, using some sort of sturdy perforated stainless material with much smaller holes than you normally find in chip pans.
    I may want to have such a thing made, and am seeking info on the material used.
    Might also have been some baskets that sat under the troughs, not a full pan liner.
    Thanks, and regards.
    Mike
    Dec 2003
    poulsbo, wa, usa
    912
    67
    393
    Mike
    McMaster carr is were I got it in the past ... and I have also seen it on ebay .. I made some in the past and just tig welded it up and then put filter cloth below it to catch the super fines that made it past the screen ,,,,
    Sep 2007
    Washington
    5,333
    209
    1639
    Thanks, but I didn't see anything that has enough thickness + small holes to do the job. I have .055" holes right now, and would like to get down to .03" or .025", and be sturdy enough to be self-supporting.
    Regards.
    Mike
    Jun 2013
    Northern Il
    1,367
    712
    1264
    Quote Originally Posted by Finegrain View Post
    Regards.
    Mike
    McMaster-Carr
    You might want to consider a backer to help support the fine mesh material.
    You also want to favor the larger wire diameters as they are tougher and stronger though they do have a lower flow rate but your application likely is not full flow.
    Aug 2012
    California, Central Coast
    4,084
    2232
    1602
    To clarify, do you want wire mesh or perforated metal, Sounds like you want perforated. Local steel supply here has it. Also mcnichols is big in perf metal.
    McNICHOLS(R) | Perforated Metal, Wire Mesh, Bar, Plank, Fiberglass Grating
    .027 and .033 looked good.
    Sep 2007
    Washington
    5,333
    209
    1639
    Quote Originally Posted by Rob F. View Post
    Thread title should have been "micro perforated", not micro mesh.
    I'll look at the McNichols site, thanks!
    Regards.
    Mike
    Sep 2005
    Oakland, CA
    2,597
    351
    720
    Not sure what you're up to, but scotchbrite pads make a pretty good fine filter and its pretty impervious to hot chips.
    Sep 2007
    Washington
    5,333
    209
    1639
    Quote Originally Posted by Dan from Oakland View Post
    Hot sure what you're up to, but scotchbrite pads make a pretty good fine filter and its pretty impervious to hot chips.
    Nothing like that. I want to make a liner for my chip pan:
    It needs to be sturdy enough to not rip or fold up when I scoop chips out, and I want something like .03" holes. The stock chip pan has .055" holes, which let too many small chips through. .03" still lets fines through, but will catch a bunch more than the .055" holes. A piece 18" wide x 40" long would give me enough to bend up short sides.
    I've tried fabrics, but it's pretty hard to scoop chips without catching and ripping or folding up the fabric.
    Socks over the trough ends are impractical since they would fill up very quickly when I'm roughing.
    Mike
    Jan 2014
    Temecula, Ca
    3,071
    1344
    3999
    in another thread not too long ago, someone suggested furnace filters. I have found them to work great, and they're cheap
    May 2005
    Interior British Columbia
    2,405
    249
    755
    If you want or just need really filtration that can be cleaned and that you can pick and choose the minimum particle size you will accept, take a look in at the irrigation suppliers and see if they have anything that will serve your needs.
  11. #11
    Jul 2011
    East Yorkshire UK
    390
    848
    306
    for the coolant filter on my lathe, I have the inside of a microwave door, very finely drilled mesh, and built into a tougher, recessed frame!
    Phil
    East Yorkshire.
  12. Likes sfriedberg liked this post
  13. #12
    Dec 2003
    poulsbo, wa, usa
    912
    67
    393
    Mike
    The pic you posted shows the coolant pump on the left side of coolant returns .. what is on the right side of the chip pan ?
    I posted up about it before but no one really seemed to interested ,,, but why not just make a simple auger setup that catches the chips and coolant coming out the returns in a "U" shaped gutter and use a auger just like Haas to lift and drop the chips in a drum ?
    You could just put a filter down in the bottom of the stock pan to catch the fines that go past the auger drain holes...
  14. #13
    Sep 2010
    Oklahoma City, OK
    4,701
    809
    1939
    Particulate filtration at this size largely comes down to fluid velocity- if you slow down the fluid, the solids will drop to the bottom. You could probably craft a drop-in tray with a set of weirs at decreasing heights for the coolant to cascade through. Each level is another chance for the coolant to stop and drop whatever carried over from the previous level. Couple that with some fine mesh and your sump should stay very clean.
  15. #14
    Mar 2006
    jacksonville,fl.
    1,193
    1016
    394
    Our Colchester lathe had a problem of chips getting into the coolant pump.Iplugged the return hole at the headstock and put one at the ts end.Shimmed the hs pan end slightly and that stopped just about all the chips in the sump.
  16. #15
    Nov 2017
    Kansas
    347
    79
    160
    Overlap two sheets. Stagger the sheets to create your perfect hole size. With not to much more work you can make them adjustable. Try a few supply houses for seed cleaning.
    Sieves can get pretty small
  17. Likes digger doug liked this post
  18. #16
    Dec 2013
    777
    239
    456
    These look interesting:
    McMaster-Carr
    Maybe you can fit one under each outlet. Run landscaping/gardening cloth (home depot) under those. When the baskets fill, empty them out. The cloth stays in. I've used magnets to hold the cloth in place up the sides of the chip tray.
  19. #17
    Sep 2007
    Washington
    5,333
    209
    1639
    Thanks everyone, I will look at all of these ideas.
    Regards.
    Mike
