Looking for Miniature Boring Mill / Face Plate Jaws - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21
    Virginia
    24,778
    7561
    7739
    Quote Originally Posted by Zahnrad Kopf View Post
    A face plate can EASILY be 0.750" and clamps 2.5" would mean I save/regain/avoid consuming 2.50". That's a 43% savings. And a big deal.
    It is entirely possible that we could even get away with a 0.50" thick face plate. And, if we consider the "jaws" that I modeled being 2.0" tall, we save SIGNIFICANT amount of work envelope.
    You are only looking at the "numbers" for space.
    You need to ALSO look at the "numbers" for stress distribution.
    Half-inch - or even 3/4" un-ribbed plate is going to flex when your work applies the advantage of leverage from points a coupla inches out.
    Try that, "static" on plate stock with some scrap and a DI before you waste time building it.
    A mere fractional thou of movement, worse "bellmouthing" at that, and... your work is no longer properly gripped, can wobble - then crash.
    Might still work for grinding, but not so much for milling or turning.
    How to counter that flex?
    Can you add a skirt and/or a hollow ring ABOVE the plate to apply jacking force to the back of the jaws directly, further up off the plate?
    The jaws and work then being gripped down inside a well or sort of "cup" to save space. A conventional chuck conceptually turned "inside-out", so to speak.
    RBK to swap workpieces, even so....
    Guessing that's why more than one size of machine tool exist?
  2. #22
    Apr 2010
    Wisconsin
    5,946
    4131
    3598
    No. No, I am not.
    No. No, I do not.
    I already have already evaluated these things, fairly thoroughly. You appear to be making some assumptions about the specific application, and they are not correct.
    ... it's always a toss up or gamble as to how much detail to offer when starting out, here. Not enough information or background, and it is unhelpful in soliciting input. Too much information and people start veering off offering anecdotal comment relating to that one time in band camp...
    From my original post -
    Looking for a miniature/smaller version of Boring Mill or Face Plate jaws.
    Unless I say otherwise, trust me to know what I want when I ask for it.
  3. Likes Mud liked this post
  4. #23
    Virginia
    24,778
    7561
    7739
    LOL! We trust you to know what you WANT, well enough.
    You're just kinda hard-headed about the road to GETTING it!
    OTOH.. that's part of what separates those who find a way to eat reg'lar like...
    ...and those others who have to rely on voting theyselves gummint handouts..
    So "press on" ....and do let us know what you finally work-up and how it works.
  5. #24
    May 2002
    South Central PA
    13,352
    2116
    3314
    Here's a tiny version of what Chuck posted.
    I think this, scaled up, made much taller, the angle greatly increased, fastener sizes increased, the moveable jaw registered to the fixed body side to side(make it wider and tight fit to the body) maybe a shallow Vee on the face, would work for shaft work. I think there are bolt holes in the machine to fasten them to w/o a face plate?
  6. #25
    Nov 2004
    Viborg, Denmark, Europe
    851
    819
    507
    Could any of AMF's products be used?
    Page 102 and onwards?
    https://www.amf.de/files/amf-assets/...nnelemente.pdf
