Looking for power feed
Likes Likes:  0
Results 1 to 6 of 6
    Apr 2012
    Central Ohio, USA
    120
    20
    11
    Default Looking for power feed
    I know it is a bit of an oxymoron, but looking for some inexpensive power feed for my Bridgeport. Preferably something that is fairly easy to install. I have mechanical skills, but don't want to have to completly disassemble the carriage to install it. I just need the cross feed, not looking for an elaborate DRO or 3 axis power feed. The unit is not going to be CAD or anything, just something to get a more uniform finish across long parts, and something that I don't have to be 100% hands on for making a part. Any ideas where to buy used or reconditioned?
    Jun 2006
    New Jersey
    3,094
    310
    276
    eBay? There appear to be dozens available most in the $200-$400 range but some used ones for cheap.
    -DU-
    Feb 2012
    Indiana
    6
    Servo is a popular brand around here. Easy to install without any modifications to the machine. On a bridegport the X-axis aka longitudinal feed (left to right) is thrust loaded on the left side of the machine. So, remove the right side handle and bearing bracket. Slip on the power feed unit using the mounting holes for the old bearing bracket. Been a while since I did one of these but seems like there are some shim washers or a bushing you may have to fit to the lead screw but it was very simple and straight forward. Don't let the name fool you. It is not a servo motor such as used in CNC. It is just a brand name. The common problem used to be the large gear in the bottom of the unit is plastic and driven by a steel gear. This arrangement did not like heavy loads and the plastic gear teeth would shear off but it was easy to replace. I do not know if it still uses this gear arrangement anymore or not. We have phased out these and added CNC retrofits.
    Apr 2012
    Central Ohio, USA
    120
    20
    11
    David, perhaps I should elaborate, I am not very sure about what fits what in this hobby/industry. I am new to machining and have seen ebay label stuff with tag phrases of equipment that it won't even fit...just to get people to look at it. I guess I should have asked what kits would fit the BP...I would hate to pay 300 for something and have it not fit....
    Dec 2011
    bis nd
    173
    20
    I have a servo 150 on my BP jhead it came on it works great but i can say if you look up servo brand you will have sticker shock 500-700 worth Iv never used a genaric but ther a lot cheaper and look to be biult off of the servo design look in enco catolge at looks/ price
    Jan 2007
    Pinckney Mi.
    2,939
    5271
    849
    Check data in The B.port Dept. here more data than you will want..
    Gw
