Looking for threaded 1/2" steel balls
Results 1 to 16 of 16
    Jun 2012
    Chicago, USA
    1,272
    9
    99
    Default Looking for threaded 1/2" steel balls
    Hi,
    Can anyone point me to a source for small (1/2" diameter, or 10-12mm at a pinch) threaded steel balls? McMaster doesn't go smaller than 3/4". I found a couple of places online, but they're asking $35-40 per 1/2" ball which is too expensive for the intended application. Seems like they should be out there, I'm hoping I'm just missing them.
    Lee
    Jun 2016
    New York
    1,386
    719
    584
    Not enough information. Female thread or a stud? What material, “steel” covers a lot of ground. Chrome bearing steel, polished to 2 micron sphereicallity, or hot forged, with mill scale? If it doesn’t matter, search lamp and lighting fixture parts, maybe nickel plated brass.
    Jun 2012
    Chicago, USA
    1,272
    9
    99
    Fair enough, sorry
    This is for a design prototype/proof of concept, so the grade of steel isn't too important. Stainless, chrome steel, mild steel, anything is fine. The surface finish should be polished but again, almost anything would work. I'd like to thread a stud into the female threaded hole.
    Sent from my SM-N960U using Tapatalk
    Sep 2014
    Georgia
    325
    252
    123
    Quote Originally Posted by leeko View Post
    Hi,
    Lee
    Bal-tec
    Stainless Steel 1/2". Less than $19.51 for 4 or more.
    Jun 2012
    Chicago, USA
    1,272
    9
    99
    Thanks for the link. That was one of the sites I looked at, but the price I see is $26.80 for 4 or more. Just seems expensive for what it is.
    Lee
    Sep 2007
    Washington
    5,110
    175
    1456
    If you don't need super-low axial runout, straightforward to simply drill and tap a 1/2" stainless ball. I did a few 100 of these some years ago. Definitely not rocket science and not $20 .
    Regards.
    Mike
    Jun 2012
    Chicago, USA
    1,272
    9
    99
    Fair enough
    I was thinking the stainless steel balls were also fairly high RC hardness. Is that not the case? I'd rather not have to go through annealing them first
    Sep 2007
    Washington
    5,110
    175
    1456
    304 and 316 1/2" are easy enough to find. $1 for 304 or $2 for 316, from McMaster-Carr.
    Regards.
    Mike
  9. Likes cyanidekid liked this post
  10. #9
    Jun 2012
    Eastern PA
    917
    223
    406
  11. #10
    Jun 2012
    Chicago, USA
    1,272
    9
    99
    Ah, great thanks
    For some reason all I was seeing are 400 series which I assumed were harder
  12. #11
    Jun 2012
    Chicago, USA
    1,272
    9
    99
    Thanks, but I'd prefer steel
  13. #12
    Oct 2017
    535
    135
    143
    Search for corona balls. They are used on high voltage electrical connections to cover any sharp points that may ionize the surrounding air.
    They may only be available in aluminum though, and they are not made to tight tolerances.
  14. #13
    Mar 2004
    Edison Washington USA
    10,283
    959
    5304
    you need to find an industry that uses them- you cant assume something exists just because you want it to.
    I cant think of a single mass produced consumer item that uses tapped 1/2" balls- but if there is one, that would tell you where to start looking.
    As mentioned, lighting manufacturers use mostly brass .
    The Piercing industry might be a source. Balls for Body Jewelry | Abbott Ball Company
    Also, if you dont find what you want on a website- it doesnt mean it doesnt exist- it just means the market is small enough, or specialized enough, that its not worth paying to put it on internet shopping sites.
    You should call up some of the big ball bearing guys, and ask, on the phone- they probably know who sells em, or might run em as specials.
  15. #14
    Feb 2013
    Madison, WI
    944
    1079
    608
    How about these? Blind Threaded 302 Stainless Steel Balls - .500 Ball Diameter $8/pc
  16. #15
    Jun 2012
    Chicago, USA
    1,272
    9
    99
    Perfect, thanks!
  17. #16
    Sep 2004
    FL
    191
    33
    You can heat bearing balls to red heat and cool slowly. Bury in coals of wood fire and come back the next day when cool. Easy to drill and tap when softened. Scrap bearing almost free except for your time.
