Ok guys,
I had to ask, am I too expensive on this shaft repair job? Well obviously I was because I just lost the job to a shop doing it for 60% less then I charged! ouch!
Part is a 50mm dia. shaft about 18" long with a step down on one end for a bearing journal 20mm dia. by .600 long. I get the shafts with the bearing journal worn down and I turn the journal to 16mm and press fit a sleeve onto the 16mm stub. Then I turn the sleeve down to 20mm for a slip fit into a 20mm bearing. I was charging $110 to do the job. No large quantity on this job, I only did 4 to 6 repairs every other month. The company I was doing the work for pulled the job from me last week and I found out today they are getting them done for $45.00 What would you guys charge for something like this?
Btw, company that was bringing these to me buys them from a German manufacturer and pays almost $600.00 ea! Shaft lasts for maybe 2 months before needing repair!
