Porschefix
Hot Rolled
- Dec 3, 2009
- Bluff Dale
This convertible bandsaw was purchased new in about 1965 from Grainger. Recently it started doing some uncharacteristic things. After cleaning the gears I found some wear on the gears, not enough to quit turning the bullwheel but has had low torque stall etc. The gearbox was packed with black, I assume moly grease of some sort, no telling. I found a pair of new gears to fit from Boston Gear and the differences between the gears is the old gears were hardened steel, the new are cast and bronze.
Boston Gear recommended Klubersynth UH1 6-460 Gear oil but after looking around it appears to cost between $40-$50 per quart, and I only need about 6 ounces. They also stated that if I used grease that it should be non-EP with the bronze worm.
My question is, can anyone recommend an easily obtained less expensive gear oil that would be good for my application? So, non-EP grease or gear oil?
