donleybill
- Jan 26, 2010
- Thousand Oaks, Ca
I have 2" X 3" X 28" rough ornate iron casting that needs to be machined around the periphery. The best surface to locate this part for machining is on the ornate side which is anything but flat.
My thought was to spread over the ornate side of the casting with an auto body bondo and parting agent. Once the material cures, it would machined flat and become the primary datum for all other milling operations. After machining, the "autobody bondo" would be come off clean with the help of a parting compound.
A life time ago I used a material called Tooling Stone. I fabricated to a simple drill jig with tooling stone to accurately locate a Cadillac badge onto a hub cap.
This material was easy to apply, didn't srink, machined fairly well and worked with a parting agent.
Today I can't find Tooling Stone and hopefully someone has a better material suggestions than auto bondo. Any suggestions would be appreciated.
This is one of two castings for model engine project.
Bill
Bill
