The subject of the infamous Machinery's Handbook comes up here from time to time, and I usually manage to make fun of it's propensity to go into the tinest minutia of information that is pretty much worthless today, like charts on Brown and Sharpe tapers and yet completely leave out info on what folks today really need to know about...like CAT, BT, R8 tapers and such*.
So, the conversation usually leads to ...well, if Machinery's Handbook sucks, what do you recommend ? So I mention the SME published Tool and Manuf. Engineer's Handbook, volume 1 and ASM Handbook volume 16....and the end result is tumbleweeds rustling past and crickets chirping....in fact, I don't know of a single other member here that has even mentioned owning these two books ! I wonder if this is partially because they are full size big heavy books ?
Anyway, at IMTS I discovered that someone has finally done a proper substitute for Machinery's Handbook. Same physical size, same sorts of info...but current stuff ! Chapters on CNC, EDM, lasers, water jet, CNC tooling, indexable insert info...even has HSK tool holder dimensions !
Also, more metric info...metric retaining rings, etc, etc
And still has all the 'basics' in great detail as well...drive belts, retaining rings, pins, springs, milling, alloys, taps, drills, reaming, etc, etc, etc
It's called 'Handbook for the Metalworking Industries' and is published by Hanser Gardner...the same folks that publish Modern Machine Shop magazine. Cost is cheaper than MH also...about 55 bucks. Same physical size as MH..maybe a 1/8 inch taller.
So, put your MH copy on eBay before folks wise up and order a copy of HMI !
Thank you Woodrow Chapman !! (the editor)
Humorously, the one irritant with HMI is they also waste paper with charts on Brown and Sharpe tapers !
*I'm basing this on info up to Edition 24 of MH and anedotal talk here. I haven't looked at the very latest edition of MH, so perhaps it has been updated since E24 as well, but judging from their past performance in that area I'd say it unlikely
