Machining a 36" diameter bushing.
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 69
    Mar 2007
    Salem,Ohio
    545
    17
    302
    Default Machining a 36" diameter bushing.
    I was getting some chatter in the bore of this bushing so i had to break out my big boring bar
    Mar 2009
    Brunswick Oh USA
    4,514
    5010
    2687
    Very cool!!
    Feb 2007
    St. George, Utah
    854
    383
    542
    That's pretty spiffy! Is the cutter clamped in a groove like seen in the back end or is it done some other way?
    Mar 2007
    Salem,Ohio
    545
    17
    302
    Yes there is a groove in each end
    Jul 2006
    Hillsboro, New Hampshire
    7,363
    1736
    5120
    Lad, you should have made the bar from rubber for extra energy absorption.
    (More seriously, I'd have swapped the compound for an additional solid riser. Or even bolted the bar to the existing riser, used an angle-ground bit, and done the math for diameter corrections).
  6. Likes TDegenhart, lumley32 liked this post
    Oct 2005
    14,854
    That job would be much better on a Bullard, a Dynatrol one at that.
    done many jobs like that, and while the end turret is doing the I.D.
    the side head can be turning the O.D. or facing.
  8. Likes eKretz liked this post
  9. #7
    Sep 2016
    Missouri
    781
    668
    221
    Pricey piece of bronze.
  10. #8
    Feb 2017
    84
    6
    31
    That's fantastic!
  11. #9
    Feb 2007
    St. George, Utah
    854
    383
    542
    Sure, but who can go get just the right machine for every job? The man has a fine solution for his needs and the result will be as good as required.
  12. Likes _boris_, 4GSR, J.Ramsey, Toolznthings, cpifer3 and 1 others liked this post
  13. #10
    Nov 2009
    Massachusetts
    306
    90
    Quote Originally Posted by cuttergrinder View Post
    Is that bar a solid square cross-section, or is it two rectangles bolted together? It looks like two rectangles.
    The reason to ask is that two rectangles bolted together have 1/8 the bending stiffness of a solid square of the same outside dimensions.
  14. #11
    Mar 2007
    Salem,Ohio
    545
    17
    302
    There is talk of us getting a vertical boring machine but right now we dont have one.
  15. #12
    Mar 2007
    Salem,Ohio
    545
    17
    302
    Its a solid bar. It was planed on the side but only half way. Not sure why. That was way before my time. It measures 8 1/2 x 6 x 8' long
  16. #13
    Mar 2007
    On Elk Mountain, West Virginia, USA
    2,091
    898
    713
    I know a shop that scrapped a $5000 piece because they were too cheap to make a boring bar.
    Good job!
    What make is your lathe?
  17. #14
    Jul 2006
    7,363
    1736
    5120
    Quote Originally Posted by Joe Gwinn View Post
    Hi Joe,
    OP's already stated it's a solid bar, but I'm curious about the "1/8th" statement. I'd agree if they were just stacked together they'd be significantly less stiff, but truly bolted together (not just in the middle) I think they'd be much closer to the solid value.
    As well, might even have a damping advantage with the two faces rubbing together helping to convert some vibration into heat. But there might be a geometry drift due to that heat, so perhaps a bit of a gamble.
  18. #15
    Jul 2004
    Houston, TX USA
    29,634
    Great looking NN Monarch
  19. Likes 4GSR, James H Clark liked this post
  20. #16
    Mar 2007
    Salem,Ohio
    545
    17
    302
    Quote Originally Posted by magneticanomaly View Post
    Good job!
    Its a a monarch NN i believe
  21. #17
    Oct 2005
    14,854
    1. The ease (and safety) of loading/unloading, increased productivity.
    2. The much increased production from the side head.
    3. The increased rigidity allowing heavier cuts.
    should easily justify one.
    Vertical Turret Lathes | O'Connell Machinery Co, Inc.
  22. #18
    Sep 2006
    SE PA, Philly
    5,305
    984
    1755
    Hi Joe,
    I'd agree - stiffness would be a function of clamping forces and surface roughness. For example, imagine two bars with 1/4" deep 60° Vee cuts on each face, cuts that mated perfectly. Then use a patttern of bolts or rivets that hold the bars together with immense force. Maybe not the same modulus as solid, but pretty close I'll bet. The old riveted box beams and such were made to be pretty stiff.
    Not sure how much heat would be generated, or what the geometry effect would be. The tighter that they were bolted together, the less heat I guess.
  23. Likes Milland liked this post
  24. #19
    Sep 2010
    Oklahoma City, OK
    4,242
    727
    1783
    Quote Originally Posted by johnoder View Post
    I believe I see a lever for a powered compound as well. Nice feature.
  25. #20
    Mar 2007
    Salem,Ohio
    545
    17
    302
    Quote Originally Posted by Cole2534 View Post
    Its not a powered compound. It has a rapid traverse on the carriage. Its actually a cable drum lathe. It cuts leads rather than threads per inch.
