Machining a 36" diameter bushing. - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 69
  1. #21
    Dec 2013
    Spennymoor, England
    50
    19
    How did you manage to get a picture of my Myford doing a bush!
  2. Likes Limy Sami, camscan liked this post
  3. #22
    Jul 2006
    Hillsboro, New Hampshire
    7,338
    1729
    5098
    Quote Originally Posted by macchi7 View Post
    He's making a scale model of the QE2, that's for one of the prop shafts.
  4. #23
    Mar 2007
    Salem,Ohio
    545
    17
    302
    Quote Originally Posted by cuttergrinder View Post
    Its not a powered compound. It has a rapid traverse on the carriage. Its actually a cable drum lathe. It cuts leads rather than threads per inch.
    Here is a couple more pictures. The one is showing the grease grooves i have to bump over. The other picture is another set i made. They are getting some holes drilled on the boring mill.
    Attached Thumbnails Attached Thumbnails 20190917_122514.jpg   20190917_122440.jpg
  5. Likes Garwood, cpifer3, Oldwrench, JHOLLAND1 liked this post
  6. #24
    Aug 2013
    IL
    62
    16
    38
    I logged in just to "like" your post. Great work.
  7. Likes cuttergrinder liked this post
  8. #25
    Dec 2004
    San Antonio, Texas
    159
    6
    200
    Nice work! Big parts, not too complicated. Me like!
  9. #26
    Nov 2009
    Massachusetts
    302
    89
    Hi Joe,
    OP's already stated it's a solid bar, but I'm curious about the "1/8th" statement. I'd agree if they were just stacked together they'd be significantly less stiff, but truly bolted together (not just in the middle) I think they'd be much closer to the solid value.
    It's straight out of Roark, formulas for stress and strain. PDFs are available on the web. Basically, the stiffness of a beam is proportional to the cube of the dimension being bent: (1/2)^3= 1/8.
    Think of a floor joist. Why is it 2x8 or 2x10, with the long dimension vertical?
    If that boring bar were in fact two rectangles bolted together, running two weld beads down the two outside seams would largely recover the stiffness. Bolts are not nearly as stiff in shear as a long weld. It's useful to think about the mechanical advantage between the two half-beams as the stack is bent.
    Now, for a boring bar, there are both bending and twisting forces, and chatter can use either or both.
    As well, might even have a damping advantage with the two faces rubbing together helping to convert some vibration into heat. But there might be a geometry drift due to that heat, so perhaps a bit of a gamble.
    There will be some damping due to friction for sure, but the loss of stiffness will dominate.
  10. Likes Gordon Heaton liked this post
  11. #27
    May 2005
    Republic of Arizonia
    1,577
    460
    I see someone else uses old iron. Good job...
  12. #28
    Jan 2005
    Victoria, Texas, USA
    3,981
    2122
    1002
    Is that another Monarch NN in the background?
    There's a local shop here in the city I live by that has two Monarch NN's and two N's the last time I was in there. Brought back memories. Ran one that came out of government storage forty years ago while I was in college. What a sweet operating lathe for it's size! Very nice work you done there. Thanks for sharing, Ken
    Ken
  13. #29
    Langley, B.C.
    1,659
    333
    969
    Quote Originally Posted by mllud22 View Post
    Pricey piece of bronze.
    That was my first thought as well. I assume it's hollow cast so not a huge amount of waste...
  14. #30
    Jul 2006
    7,338
    1729
    5098
    Quote Originally Posted by Joe Gwinn View Post
    Sure, for two pieces laid on top of one another. But for a truly bolted section (again, not just the middle), the stiffness will not be hugely off the value of a solid bar. I agree that bolts don't magically pin parts together 100%, but done correctly you'll recover ~80% of the unitary stiffness.
  15. #31
    Jun 2016
    New York
    1,496
    816
    644
    thats a decent boring bar.. lotta torque on the tool post tho for sure! the "spring pass" must be .005 or more.. even in bronze.. (well maybe not on that dia)
  16. #32
    Mar 2007
    Salem,Ohio
    545
    17
    302
    Quote Originally Posted by LKeithR View Post
    They are cast in 2 pieces. The splits are milled and tack welded together and then turned. There is not a huge waste but i bet i got 300 lbs off that bushing. The 2 halves weigh about 1,600 lbs when i start.
  17. #33
    Mar 2007
    Salem,Ohio
    545
    17
    302
    Quote Originally Posted by 4GSR View Post
    Ken
    Yes the other lathe is smaller dia but longer. I believe it will swing 30" over the carriage x 20' long.
  18. Likes 4GSR liked this post
  19. #34
    Oct 2005
    14,816
    There are (2) shops nearby that make very similar parts:
    1. Verticalseal in Pleasantville, pa: Vertical Seal Company
    2. us bronze in Meadville, pa: Welcome
  20. #35
    May 2007
    Massachusetts
    1,420
    460
    1218
    Only the best guy in the shop gets trusted with a piece of material that costs this much. Nice job, guys like you add a lot of value and credibility to the shops name .
    Make Chips Boys !
    Ron
  21. #36
    Mar 2007
    Salem,Ohio
    545
    17
    302
    Quote Originally Posted by Dupa3872 View Post
    Make Chips Boys !
    Ron
    You mean if i mess this one up , i cant order a replacement from mcmaster-car. Now im nervous. Lol
  22. Likes TeachMePlease, Oldwrench liked this post
  23. #37
    Nov 2009
    Massachusetts
    302
    89
    Hmm. How does one achieve that 80%? Especially in twisting.
  24. #38
    Jul 2006
    7,338
    1729
    5098
    Because stiffness is material strain at some MoI. If you have the same MoE, and have bolted along the edges (just as you'd see with fabricated box beams in older built-up bridges), then whatever load you're applying will try to strain material to (essentially) the edges of the geometry, and create the counter to applied load. So not the full equivalence of a solid element, but a good portion of it.
  25. #39
    Jan 2016
    New Jersey
    216
    66
    95
    This also assumes that the deflection is not high enough that the second beam is under load. The complexity of the interaction if they're not attached makes for a fun analysis problem or a pain in the butt depending on your feelings about the work.
    Attaching the beams at the end using almost any method will put the setup a lot closer to the original value than the 1/8 value.
    Now, this would kind of beg the question of why someone would design it using two separate bars, but as neither OP's work nor anyone else as far as I know has, I think we can just close the case on it.
  26. #40
    Dec 2012
    OHIO
    250
    237
    204
    How exactly do you do the grooves?? very cool!!
