Machining a 36" diameter bushing. - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 69
  1. #41
    Jan 2015
    117
    33
    41
    If the 2 beams were merely in full contact, then it seems the stiffness should be 1/8 * 2 = 1/4 that of a solid bar, not?
  2. #42
    Sep 2010
    Vancouver Canada
    898
    648
    315
    This is a great post by the OP. You read the title and you're like, "Oh dear heavens it's gonna be a guy trying to make a massive part on the wrong machine, like a Bridgeport mill or something, and everyone's going to be arguing about getting a proper tool or coming up with increasingly outlandish methods to make the thing". So you click on it with a rising sense of outrage about the things you haven't even read yet, and instead you get his massive boring bar giving the middle finger to your technical pretensions. Nice job!
  3. #43
    Oct 2005
    14,835
  4. #44
    Apr 2014
    Dutchess County NY
    365
    90
    90
    Wow. I'm shocked at the low price. It even comes with a DRO! ;-)
  5. #45
    Nov 2009
    Massachusetts
    302
    89
    Because stiffness is material strain at some MoI. If you have the same MoE, and have bolted along the edges (just as you'd see with fabricated box beams in older built-up bridges), then whatever load you're applying will try to strain material to (essentially) the edges of the geometry, and create the counter to applied load. So not the full equivalence of a solid element, but a good portion of it.
    Well, I'll probably hit the books this weekend. My instinct is that it's difficult to get that kind of stiffness out of ordinary bolts, no matter what. In the old days, they used hot rivets, which do cinch up quite tight.
    What would work would be high-tensile structural bolts that are torqued to 70% of yield, using hydraulic tools, with a bolt tang that snaps off when the proper torque or strain level is reached. I don't recall the standard number, something like A325, but they are used in steel framing in place of welding, in fields of bolts in a hex grid. They did care about use of paint on slip-critical surfaces, even at that clamping pressure level.
  6. #46
    Mar 2007
    Salem,Ohio
    545
    17
    302
    Quote Originally Posted by cpifer3 View Post
    How exactly do you do the grooves?? very cool!!
    The grooves are cast in .
  7. #47
    Mar 2007
    Salem,Ohio
    545
    17
    302
    I showed this to the boss
  8. #48
    Jan 2005
    Victoria, Texas, USA
    3,983
    2127
    1002
    That Bullard doesn't have enough column height to setup and bore out that casting IMO. That's probably why they are letting it go cheaply.
  9. #49
    Mar 2007
    Salem,Ohio
    545
    17
    302
    Quote Originally Posted by 4GSR View Post
    You are probably right. Also dont know how i could mount my 8' boring bar on there . Lol
  10. #50
    Mar 2007
    Salem,Ohio
    545
    17
    302
    I tried to bore the bushing with my next smaller boring bar which is 4" and it just vibrated horribly. The big bar didnt chatter at all.
  11. #51
    Oct 2005
    14,835
    I'm not seeing what your seeing.
    The cross rail looks like it may just be high enough as it sits, and appears it can go higher.
  12. #52
    Mar 2007
    Salem,Ohio
    545
    17
    302
    It may go high enough but getting a big enough boring bar in there may be a challenge.
  13. Likes 4GSR liked this post
  14. #53
    Nov 2015
    334
    113
    Quote Originally Posted by NRDock View Post
    No, because the neutral axis of the system is now between the bars, so each half is effectively taller.
    Quote Originally Posted by Joe Gwinn View Post
    Fully admitting that I'm just throwing fuel on the fire here. Why not move to torque+angle if you're going to go that far? A snap off tang can do a good job of maintaining desired torque, but torque carries a less than ideal correlation to installed fastener tension.
  15. #54
    Nov 2009
    Massachusetts
    302
    89
    No, stiffness varies as the cube, not the square, of the cross-section width in the relevant dimension. Look at Roark's formulas for stress and strain for the actual formulas. There must be a derivation somewhere as well. Also, it's pretty easy to test.
  16. #55
    Jun 2001
    lancaster,ohio.43130
    914
    14
    136
    Inquiring minds need to know............. If the standard press fit is generally .001 per inch of diameter, does that mean that bad boy gets .036" of press?
  17. Likes memphisjed, TeachMePlease liked this post
  18. #56
    Mar 2007
    Salem,Ohio
    545
    17
    302
    Quote Originally Posted by mark costello View Post
    The body of the bushing in 33.655. I have no idea what the bore size of the housing is.
  19. #57
    Apr 2004
    Modesto, CA USA
    6,798
    1131
    Out of interest, how do you measure the diameter that accurately. Do you have some really big micrometers or what?
  20. #58
    Mar 2007
    Salem,Ohio
    545
    17
    302
    Quote Originally Posted by Bill D View Post
    Yes we have big mics. I think we have to 54" mics.
  21. Likes BoxcarPete, TeachMePlease liked this post
  22. #59
    Nov 2018
    Michigan
    282
    138
    161
    Quote Originally Posted by cuttergrinder View Post
    Man, that's impressive. The little 1/4-40 guy on the end just looks so out-of place. Must be a bear to make sure you have both ends on center, or do you use a jig?
  23. #60
    Mar 2007
    Salem,Ohio
    545
    17
    302
    Quote Originally Posted by BoxcarPete View Post
    We didnt make the mics. Im not sure who manucatured them. These are not the mics i used on the bushing. Just a picture i had on my phone. I dont think this picture was even the biggest ones.
