Machining 5N Aluminum?
Results 1 to 7 of 7
    Sep 2017
    Arizona
    62
    11
    Default Machining 5N Aluminum?
    Anybody ever work with this gummy stuff? Any tips or tricks?
  2. Likes jeffk liked this post
  3. #2
    Jul 2006
    Hillsboro, New Hampshire
    13,050
    2946
    8960
    What operations are you trying? Tapping will be worst, I'd think. I'd try some alcohol as a coolant, but try not to breathe the vapor.
    If your customer requires super-cleanliness for the final parts, find out from them what coolants/lubricants are acceptable.
    Sep 2017
    Arizona
    62
    11
    Turning, facing, drilling, boring, threading. Tried some with a brazed carbide tool today, it's ugly! Ordering some HHS now. I had it spinning @1140 RPM, part is about 1" dia. Figured faster the better for this stuff, but maybe slow would be better?
    Jul 2006
    13,050
    2946
    8960
    Pure Al is like machining bubble gum, so dead-sharp high shear tooling, small DOC, and a good lubricant are your friends. Look for insert tooling for finish cuts on Al, they should have the clearances and geometry to work in your favor.
    Beware of trying to hold the work in a chuck, collets are probably safer due to better distribution of contact loads (hope you're using collets now). Threading will be better with inserts meant for Al or hand ground HSS with good shear angles and a fine finish grind (inserts would be my first choice.
    Sharp drills, sharp boring tools - did I mention sharp? If you have freedom of using whatever lubricants you can get a good, no sulfur oil - some chemicals in addition to sulfur will attack Al, so make sure it's Al-safe.
    Good luck...
    Jan 2007
    wales.uk
    1,728
    360
    388
    How about diamond?
    Aka PCD
    mark
    Sep 2017
    Arizona
    62
    11
    i'm thinking i might try lost PLA casting to near finish size.
    Feb 2014
    WI
    27
    17
    Quote Originally Posted by no704 View Post
    Use PCD diamond inserts if you can, for drilling I would suggest cobalt drills or polished. Tapping go for thread forming non coated bright finish. Use lube! Microsol 690xt is what we use in the cnc machines. PCD diamond we run about 2800SFM carbide about 1500 cobalt drills 300SFM taps 150SFM
