Machining a large radius, on a large part, on a manual mill
Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    Apr 2015
    Iowa
    17
    19
    Default Machining a large radius, on a large part, on a manual mill
    We received an RFQ from a very steady customer to make a 'heavy duty' version of an assembly we have been making for them for many years. For the most part it the same thing we've always made, just bigger. But, there is one feature of one part that has me thinking twice about the approach.
    We need to machine a 2.25" radius 'half moon' into the side of a 1"x3" piece of CRS 1" deep into the flat side and all the way through the short side. On a 'standard duty' version of this part the feature is a .75" radius so we use a 1.5" diameter indexable mill and plunge mill to the required .375" depth - no problem. That same technique on this HD part would require a 4.5" mill. Again, no problem, except that our shop is 100% manual with R8 spindles. I'm concerned I'm going to beat our mill(s) to death trying to cut that feature plunging a 4.5" mill. A rotary table is out of the question because this part is 175" long. So far, it's just one part for one assembly, so maybe I can get away with it. However,in the event it shows up again I would like to have a reliable solution.
    I would love to hear some ideas if anyone has any. Of course it could be subbed out or I could rent some time on a buddy's CNC (6 hour round trip with a 14' long piece of steel) but I would like to avoid that if possible.
    Oct 2009
    Olympia, Wa
    657
    306
    195
    I would use a boring head set to that radius and just step it over a little bit at a time. No it wouldn't be as quick as plunging with a large endmill, but you can get the job done.
    Jul 2004
    Houston, TX USA
    30,286
    Drill close little holes in an arc, bust out that chunk, then finish up with the boring head / flycutter or whatever
    Naturally it won't be as fast
    The point is is that it gets done with the least fooling around making chips on inadequate machinery at your disposal
    On Edit - a job made for the K&T 2D rotary head mill
  4. Likes eKretz, Pathogen, Dumpster_diving, cranium liked this post
    Mar 2005
    Kansas
    7,634
    440
    3538
    I would scribe the radius and mill close to the line with a 3/4 rougher. I would then finish it with a boring head.
    If you are fabricators, I'd rough the radius in with OA torch (or plasma, if you have one that big). Knock the high spots off with a grinder. Then finish with a carbide tipped boring bar.
  6. Likes CalG, Erich liked this post
  7. #5
    Mar 2005
    Northwest Indiana
    4,286
    922
    898
    I wouldn't take a torch anywhere near that thing. The end of that bar would be bent to high heaven by the time you got that burned out. I'd run with the drill method that John mentioned. Quick and easy and done in one setup. It is also worth mentioning that if you take all that out of one side of a piece of cold-rolled you're going to end up with a bend anyway as the stress relieves itself when that much steel is removed from only one side.
  8. Likes eaglemike, Matt_Maguire, NC Rick liked this post
  9. #6
    Jul 2010
    corvallis,or
    877
    89
    369
    Volstro rotary milling head
    Sent from my XT1710-02 using Tapatalk
  10. #7
    Sep 2005
    Dunstable, UK
    33
    18
    Quote Originally Posted by Blazemaster View Post
    Definitely use a boring head, the stiffer the better .
    Tony
  11. #8
    Dec 2012
    Se Ma USA
    1,598
    125
    889
    Rough it out with an annular cutter. I'll bet that as its a partial circle you could rough it with a decent hole saw. Plenty of chip evacuation with the open side. Bend it back straight before finish pass.
  12. Likes JohnMartin, gary-sc liked this post
  13. #9
    Mar 2014
    Michigan
    775
    132
    275
    Depending on how tight the tolerance is, I’d rough it on the shaper within .010”, mount the fat wheel on the surface grinder, dress the radius and finish to size. If they don’t want a sharp edge at the top, dress the entire form on the wheel and have at it. If you ever have to make another, you have a wheel ready to go.
    Andy
  14. #10
    Oct 2010
    Dewees Texas
    2,435
    28
    665
    So many ways to skin this cat, all of them pretty good. Choose the one that fits your personality and tools on hand best. Guy Lautard published a little hand book telling how to generate arcs and radii on manual machines. With a 1/2 or 3/4 end mill one could do that and have a bunch of cusps approximating the desired radius. Finish with a boring head or flycutter and you are there. A person could fake it by just scribing a line with a compass and milling up close to that line in .1 inch steps then finishing with the boring head/flycutter.
  15. #11
    Dec 2002
    Benicia California USA
    8,183
    1863
    2515
    Quote Originally Posted by Hobby Shop View Post
    Andy
    Must have missed the part about the material being 175" long? Radius dressed wheel then you are running the stock across the chuck? Must be a pretty big grinder.
    Fly cutter or boring head....One machine ,one setup.
    Cheers Ross
  16. Likes eKretz liked this post
  17. #12
    Sep 2010
    Oklahoma City, OK
    4,590
    791
    1891
    Scribe the line with the boring head, plunge cut the bulk of the material with an endmill, then fnish with the boring head. Using the bolt circle function of your DRO (or some math) should lead you to a very predictable load on the finishing tool.
    If you think this will be a repeat, it may behoove you to build an adjustable flycutter to perform the finish cut.
  18. #13
    Jul 2006
    rochester, ny
    1,943
    401
    558
    Dimensions on the drawing are only to 2 places, hundreths of an inch. Seems a hole saw could hit that tolerance
  19. #14
    Oct 2005
    16,108
    ...and when this job is completed, start looking for a manual/cnc mill.
    One of those "easy to learn" bedmill type with no toolchanger.
  20. Likes AlfaGTA, Hbjj liked this post
  21. #15
    Mar 2014
    Michigan
    775
    132
    275
    Quote Originally Posted by AlfaGTA View Post
    Cheers Ross
    Yep, Totally missed the 175” part.
  22. #16
    Aug 2015
    Illinois
    1,433
    1021
    621
    Do you have a DRO with a bolt circle function? Use it to plunge many times around the arc. Spacing of the plunges will depend on the diameter of your tool and the allowable scallop.
  23. #17
    Apr 2015
    Iowa
    17
    19
    So many good ideas, thank you all. The boring head seems so obvious now I'm almost embarrassed I hadn't thought of it myself.
    I'll likely rough it out by plunge milling with a smaller endmill to a scribe line and finish with the boring head (basically exactly what Cole suggested). I won't have to buy any additional tooling this way.
    As far as DRO goes... none of that here either (I know, I know, I've got quotes on new machines with 'all' the bells and whistles). Richard pointed out the loose tolerances, these features are +-.030 which is wide open - absolutely no problem to hit with any of the above mentioned techniques on my archaic machines.
    I've never heard of Volstro head until now, what a neat piece of equipment. This is a nearly perfect application for it.
    Again, thank you all. I'll be sure to let you know how it goes (assuming we get the job).
  24. #18
    Sep 2002
    People's Republic
    3,488
    301
    2246
    Lemmee get this straight, 3 inch deep, 2.25 radius
    R8 spindle
    Punch a clearance hole in a piece of aluminum to act as a spacer[or make a soft jaw]
    Do the math for a half dozen spots on the radius, .02 under, with a 3/4 end mill, plunge
    finish with a boring head
    [edit] as you decided, no DRO sucks
    dammit man, get into the 1980's!
  25. #19
    Jun 2007
    Vancouver Island, B.C. Canada
    1,817
    46
    207
    With such tolerances if you happen to have a 2.25" annular cutter then just clamp a scrap piece of 1x3 to the edge and drill through on the correct centre point. Very fast and easy.
    (Gustafson it is just a 1" deep bore)
  26. #20
    Sep 2015
    441
    22
    186
    I agree with the hole saw technique. It’s fast and super cheap. You can easily follow it with a boring head or a fly cutter to clean up the finish if necessary.
