Machining magnesium - some generally useful information
Results 1 to 6 of 6
    Jul 2006
    Hillsboro, New Hampshire
    8,187
    1928
    5767
    Default Machining magnesium - some generally useful information
    Hi all,
    I've done a fair bit of Mg machining, but am always looking for more tips on it. I stumbled across a site that seems to have a number of good pages on it, so I thought I'd share a few:
    Cutting:
    https://www.luxfermeltechnologies.co...sium-ST1-1.pdf
    After machining:
    https://www.luxfermeltechnologies.co...m-2.2-S.._.pdf
    There's more on the site, including how they make purposely corroding alloys for a variety of uses - interesting stuff! [For nerds - not that there's anything wrong with that...]
  2. Likes Gordon Heaton liked this post
  3. #2
    Feb 2007
    St. George, Utah
    976
    515
    649
    That is good, concise info. Thanks.
    Apr 2018
    3,666
    1664
    Hi all,
    Cutting:
    This seems to be oriented to high volumes ? I am pretty happy with hss, it's easier to get the tool really sharp and put a big radius on the corner. They don't mention the big gotcha in engine lathe work - turning a diameter is fine but when you get to a corner and stop, you get a long thin string that catches fire instantly. There's no way around it. If there's any chips on the ways or pan, uh-oh.
    Never had a problem milling but hate turning, for that reason. All my parts have corners.
    Get used to little fires, try to avoid big ones
  5. Likes AlfaGTA liked this post
  6. #4
    Jul 2006
    8,187
    1928
    5767
    Huh - never had a problem with ribbon fire at shoulders. I did keep SFM down, and used sharp tooling (Al-specific inserts or ground HSS), but this was sciencey-work, not production, so I wasn't under pressure to pump the stuff out.
  7. #5
    Apr 2018
    3,666
    1664
    You've got faster hands
    Yeah, these were 10" diameter parts so mea culpa, coulda dropped the speed some. But it's such a temptation to go fast, mag cuts better than butter.
  8. #6
    Nov 2004
    Webster Groves, MO
    7,454
    1897
    3479
    Many years ago some kids in The Rolla School of Mines turned a bar into shavings enough to fill an automobile, stuffed it in a junk car, towed it into the center of town, and lit it. Back then the firefighters were not so well versed in coping with this sort of thing and they turned a hose on it. Hoo Haa.
    Bill
