Odbalmotorsports
- Feb 16, 2014
Hi Everyone!
Been working on this for a while now.. I am turning wheel bearing carriers out of an unknown alloy DOM steel tubing.. I will then be pressing in the wheel bearings. the outer shell of the bearing is about 3" and I need to turn the housings for an interference fit. I've found several engineering documents describing the different fits, but I'm not sure what class this application would fall under. is there a rule of thumb of thou per inch of diameter? or something like that? 2ndly since these are one off's I've been milling over a .010 coating of nickle, chrome for corrosion resistance inside the assembly to make it so the bearing and housing don't become one, what worries me about that is thickness variations, and delamination. so the 2nd option would be a coating of paint on the outside, and anti-seize. anyone have any thoughts on this? Thanks folks!
