Hi all, I`m lathe turning some .500" round silver steel using HSS cutters and would like to know how to get a good surface finish. It`s for a rifling head cutter so needs a good smooth finish. Have oil/water coolant and or cutting oil, just can't seem to get a nice finish. thanks, Homebrew.357.
"silver steel" was once simple. Air, water, oil hardening. No longer so simple. First you need to know WHICH.
Then there is HSS. IF one is a crackerjack shaper-of, finish grinder of, and final honer of, knows the angles, the TP settings, feeds DOC, and all that and WHICH HSS for what work? Cheaper than carbides.
If
not yet so expert?
Either:
Learn that. Millions before you did so.
Else:
Ask for recommendation, that metal, an insert maker and code known to work well, and at what RPM/SFM, feed, DOC, and coolant, if any.
Just go and buy that carbide insert maker and code, duplicate the usage guidance, grind NOTHING at all.
HSS is flexible and willing stuff.
It still arrives as just
unshaped metal. It cannot take end goals as "mission type orders" on its own. YOU have to do ALL of that FOR it as to selecting, shaping, setting, and the parameters of its use.
Page two:
Legacy HSS users were also accustomed to doing final finish with files and abrasives. Often.
Users of modern inserted carbides? Near as dammit
never.
