Dilettantism101
- Oct 24, 2021
Hello,
I am devising a method for machining 8 deg. tapers into 1/2 ground dowel pins... on a mill.
Currently, my idea is to mount a 5C rotary indexer in the vertical position on the table and use a conical
endmill to take incremental passes into the taper while continuously rotating the part.
Is this a reasonable method? I need these pins to be as concentric as possible and unfortunately can't find anything off the shelf. Any other more precise methods, omitting a lathe?
