Machining Thin Wall SS Component (0.004", 100 micron wall)
Page 1 of 2 12 LastLast
Results 1 to 20 of 37
    Sep 2018
    Ohio
    11
    Default Machining Thin Wall SS Component (0.004", 100 micron wall)
    I have a thin wall (0.004", 100 micron) 316 SS component that we are finding very difficult to get manufactured. Here's a link to the drawing.
    The component is part of a prototype 1-watt stirling engine. If the design is successful, this could lead to a project to build these engines for space use to power sensor packages on various planets and moons in the solar system.
    We didn't have much luck getting quotes to get this part made as-is so we decided to manage the manufacture of this part ourselves. It was easy enough to get the outer features turned and a blind a hole drilled into the middle. The trouble came we tried to plunge EDM the ID. Whenever we did the thin wall section the part would just disintegrate. It didn't seem that we could EDM something that thin.
    Now we're thinking that we should encase the part in a fusible alloy (like Cerrotru) to make the wall thicker prior to EDM.
    Alternatively, we could finish the ID first, then fill the part with Cerrotru, then finish the o.d. features to get the required wall thickness.
    Does anyone have any idea about what approach to manufacturing this part might make the most sense?
    Jan 2007
    Norfolk, UK
    17,489
    13147
    12851
    Make it a fabrication.
  3. Likes UCRmachine liked this post
    Sep 2007
    Maryland near DC
    335
    76
    65
    Does it have to be 316? I had a colleague many years back who made very thin section things by electro depositing nickel on a form. Make the forn, coat with a conductor, deposit the nickel, dissolve the form away.
    May 2009
    Canandaigua, NY, USA
    2,689
    125
    1114
    CAD rule #1- Don't draw it if you don't know how it can be made! IMO, the suggestions for a fabrication or deposits are good. The precision bellows are made by depositing and can be much thinner. Maybe it could be ground on a mandrel, but no matter what you do, it won't be cheap.
    Sep 2018
    Ohio
    11
    Quote Originally Posted by Limy Sami View Post
    Do you mean make it from multiple components? I imagine making a thin open ended tube would be easier and then we could have two other components brazed onto it.
    Apr 2015
    Connecticut
    417
    241
    174
    Interesting how they dimension the part on the OD and ID of the thin wall section based on the tolerances given you could make it a .01 thick wall if it weren’t for that thickness callout. If I was you I would shoot for a .0055 thick wall since the tolerance allows it on the OD. Make a mandrel and turn it. It may only be a thou and a half but when things are that thin it makes a big difference. Rough it out then with a very sharp positive angle bit cut off the last bit of material it may take a couple of passes but you can get it there. The trick is to apply as little cutting force without dragging the tool creating heat and dulling the tool which in turn creates more pressure. Since it’s 316 you should be ok as it’s very stable.
    Sep 2018
    Ohio
    11
    Quote Originally Posted by mnl View Post
    Anything could work but it needs to be strong enough to hold 150 psi with one end of the tube at about 750 deg F while minimizing thermal conduction along its length. I think pure nickel has much higher thermal conductivity and lower strength than stainless steel but that doesn't mean it won't work.
  9. #8
    Sep 2018
    Ohio
    11
    Quote Originally Posted by Conrad Hoffman View Post
    A vendor drew this up for us on a contract. Of course, we had to get all of the components manufactured for this engine so we gave the same vendor a contract to go procure the components. They have been struggling to get this part made. They told us they are going to have a cylinder that is 0.012" thick rather than 0.004-6" thick made at a cost of several thousands each with some other geometric modifications they didn't ask us about first. That's why we're kind of looking into figuring out how to get this made ourselves.
    We had a guy who knew how to make these parts for us but he signed a contract with some company and he can't make these for anyone else now.
  10. #9
    Nov 2013
    Utah
    3,744
    1021
    2065
    The over burn of a Sinker is going to blow the walls out. An experienced guy with a Wire machine will be able to burn the ID out. (Maybe)
    You have .005mm on Cylindricity call out, on a Feature that needs to be in Position to .01mm!!!! IMHO you are never going to be able to achieve that. I can't even think of a plausible way to inspect something like that. A CMM won't do it, you can't put hard gages to it, Fit and ultimately Function is the only test I can see. As an assembly, the part might be manufacturable as is.
    R
  11. #10
    Sep 2017
    South Carolina
    350
    269
    270
    I believe you need to go back to drawing board and come up with something that is more easily manufactured. Maybe start with hypodermic tubing and have the other 2 pieces laser welded/ brazed on? I have seen .004 laser weld before many years ago. I feel sure with modern technology something viable could be found.
  12. Likes Milland, Newman109 liked this post
  13. #11
    Jul 2006
    Hillsboro, New Hampshire
    5,755
    1365
    3986
    Quote Originally Posted by crazygoat View Post
    Yes, hypo tubing with silver soldered fittings would be the way I would go with this. Would make it dramatically cheaper to build and much less effort. Proper soldering and cleaning would be needed to ensure no residual flux was left behind.
  14. #12
    Aug 2005
    CT
    7,850
    282
    1726
    I believe you need to go back to drawing board and ...
    Well, I have not even got beyond the .434 +/-.001 @ 3.5" depth bore with a flat bottom thing.
    Then the 750F temperature with conduction issues... on SST?
    I ain't no metallurgist, but Inco ( even if it's lower strength than SS ) is gonna be a better choice at those temperatures.
  15. #13
    Jul 2006
    5,755
    1365
    3986
    Quote Originally Posted by SeymourDumore View Post
    Fair enough on calling out the temperature. A286 would work, but a Inconel 718 might be a better choice. And that means brazing, not soldering for assembly.
  16. #14
    Oct 2011
    Stockholm, Sweden
    122
    43
    Laser welding from multiple parts would be the way. You should first find a company that are experts in laser welding and talk to them. Then redesign the part after their input.
    /Staffan
  17. Likes rcoope liked this post
  18. #15
    Mar 2011
    SWITZERLAND
    966
    114
    373
    I see round bar on a swiss lathe, turning one end features, deep drilling, turning other end features, honing ID, and a well cooled grind operation for the OD, part on a quill.
  19. Likes dgoodell liked this post
  20. #16
    Dec 2004
    uk
    13,688
    4200
    6397
    I second You Mechanola thats how i would make it. Once you have got that ID honed out with the right tooling approach you should be able to turn it pretty thin on a mandaral, certainly into the sub 20 thou range and then grind from there.
    Yeah its going to be expensive and also very easily damaged, but design shit with zero thought to manufacture and thats what you get. Still can not realy see why everyone wants to use Stirling engines in space, thermopiles and solar are far more proven and significantly less liable to fail unlike a moving component engine.
  21. Likes dgoodell liked this post
  22. #17
    Sep 2018
    Ohio
    11
    Quote Originally Posted by adama View Post
    I absolutely agree with you about the design not considering manufacturing. Our contractor who designed this part is also in charge of getting it made and they haven't had much success. We're trying to figure this out ourselves kind of late in the game so all the feedback (even the negative) is very beneficial. It sounds like it may be best to redesign this part ourselves working with a manufacturer.
    The stirling engines are attractive because they open up a lot of possibilities in space, without them there are lots of things we simply can't do. If you want enough power for human missions to mars then some kind of heat engine will be required to produce enough power. The thermoelectrics are so inefficient that can cause problems, solar power only works when you have ample sunlight. It's even difficult to make a moon lander that's solar powered because the moon's night is 15 days long.
  23. #18
    Sep 2018
    Ohio
    11
    The 316 stainless loses a lot of its strength at that temperature but it has enough margin that it should still be ok. It meets the BPVC (boiler pressure vessel code) requirements taking into account strength loss at that temp. For space flight, we can use Inconel 718 up to 650C (1202 F) and we can use Mar-M-247 at up to around 850C (1562 F). You can get a little hotter if you accept reduced life or higher risk.
  24. #19
    Feb 2004
    peekskill, NY
    24,055
    4169
    Step one: find a supplier for 11 mm OD by 0.004 wall stainless tubing.
  25. #20
    Dec 2004
    uk
    13,688
    4200
    6397
    Quote Originally Posted by dgoodell View Post
    Yeah ok, spose im not use to have to consider a 15 day night, on the plus side, 15 x24 hours would sure mean i might not wake up tired, but can't imagine sleeping that long with out a few pees even at my age!
    If your haveing issue getting it made, you need to find some of the medical suppliers, theres plenty of people there in the states that could make that for you, medical type stuff are use to long thin tubes its kinda there starting point for stents and such, might be worth contacting Implex (sp) who is a member here and makes all sorts of weird bits but this might be too big for him. Im pretty dang certain i could make the tubular part here with out issue and that's just turning it, my problem is i could not hit some of the other tolerances on that part on the end bits. I just don't mesure to that kinda accuracy but i can certainly turn very very thin walled tubes Would not be entirely wrong to say i have done near half that wall thickness before in 316.
