cjarnutowski
- Apr 13, 2017
Hi All,
I'm not a machinist by trade, so I'm hoping I can draw on someone's wisdom here.
I'm tasked with finding a way to prepare the sheared edges of titanium (CP, 6Al-4V, 15-3-3-3) and Inconel (718, 625) sheet metal tubing blanks to be welded (automated GTAW). We currently spend ~10,000 hours annually manually filing the edges of these blanks, with inconsistent results. The primary requirements are straightness and surface finish on the edge.
These sheets are .020-.080 thick, and the depth of cut we would require is on the order of .002-.004. Is it possible, with some combination of tool geometry, tool material/coating, speeds, feeds, etc. to achieve decent tool wear under these conditions? My understanding is that such lights cuts on nickel alloys will burn up cutters in no time.
Thanks for the help!
Chris
Chris
