Machinist Chest Felt is Moldy
Results 1 to 15 of 15
    Jan 2019
    Hawaii
    540
    226
    103
    Default Machinist Chest Felt is Moldy
    I just pulled my old Kennedy chest out and see that there is some light colored mold in some of the drawers. I want to start using this box again and was wondering if any of you guys have any wisdom to share or how you might have handled it. I bet it is going to be hard for me to find Lysol at the store considering but then again I am not sure having my instruments sitting on cloth with Lysol residue is smart either.
    Jul 2006
    Hillsboro, New Hampshire
    8,970
    2151
    6220
    Do you have a dehumidifier in your shop? If not, get one before you bother trying to deal with the mold.
    Then you'll be best off stripping out the old felt, soaking the rest of the bits in a bleach solution (not too long, watch for paint damage or rust), dry thoroughly, and cut/glue fresh felt in.
    I bet our woodworking crew would have some thoughts on this too.
    Jan 2019
    Hawaii
    540
    226
    103
    I am temperature and humidity controlled where I am now but the previous 15 years wasn't! The felt looks good I was once a layout man so no real dirty stuff or oily items in there. Looks good for being 30 years old....just that mold and now I want to put lathe tooling in it.
    Nov 2009
    Massachusetts
    429
    142
    Quote Originally Posted by Kevin T View Post
    I'd try vacuuming it.
  5. Likes Kevin T liked this post
    Mar 2014
    Michigan
    536
    100
    313
    A few years back I spoke with a contact at a felt mfgr. She was extremely knowledgeable in felt types and properties. It was her opinion that felt is a poor choice for tool storage, because it tends to hold moisture. Her preference was for a rubber pad or similar. That hurt, because I like the classic look of felt.
    There are many internet mentions of tools that rusted only on the underside, where they contacted the felt. My notes say Gerstner uses 100% acrylic felt.
    You also have to consider the adhesive, and whether it attacts and holds moisture.
    Nov 2006
    Southern California
    1,017
    7
    120
    I have heard of folks putting moldy items under an up side down cardboard box outside with an ozone generator also inside to kill off the mold. Also hear of it being used to kill off mold in houses with water damage (like leaking pipes). I also hear it is not good for rubber products with extended exposure to ozone. But that should not be a problem for a Kennedy tool box.
    Jun 2012
    Michigan
    11,325
    3877
    3995
    Bleach is claimed to work but only kills surface mold.. peroxide penetrates to kill mold deep into wood and kills the same for a steel box..
    Set the whole box with draws out of it out in the sun after a wipe with a peroxide wet/damp rag.
    Steel box would get an oil wipe after good and dry.
  9. #8
    Jan 2019
    Hawaii
    540
    226
    103
    Thanks for the tips guys. I did the vacuum and that was pretty good. I am not concerned anymore about the felt but will consider the peroxide and sun dry out too. Thanks again!
  10. #9
    Mar 2009
    5,586
    103
    1079
    Take some fresh pine sawdust and sprinkle it onto the mold. Use a tooth brush and brush the saw dust around. Then vacuum again.
    I learned about sawdust in 5th grade when a girl threw up her early morning gruel. The janitor poured sawdust on the pile and swept it away.
  11. #10
    Jun 2012
    Michigan
    11,325
    3877
    3995
    New felt the way to go..I like green.
    Yes after the box has been de molded..
  12. #11
    Sep 2005
    Oakland, CA
    2,648
    373
    745
    Yes, Chlorox will do a pretty good job of killing mildew and most molds, but using bleach has its drawbacks. I've have VERY good luck using good old white vinegar diluted with water for removing and killing this stuff.
    In fact, vinegar is a very good cleaning agent in general. Plus its cheap and plentiful.
  13. #12
    Apr 2004
    Modesto, CA USA
    7,377
    1282
    Not sure if wool felt is better or worse. Wool will hold the moisture into itself and in theory the tools stay dry. The other theory is synthetic felt holds no moisture so the tools stay dry.
    Bil lD
  14. #13
    Dec 2000
    Bremerton WA USA
    10,710
    41
    4371
    Household bleach is (usually) a 3% solution of sodium hypochlorate in water and its residues are a rust hazard. Bleach has long been a remedy for mold and removing its discolorations. While it may clean up the felt, inexplicable and vexing rust spots may bloom on your find precision tools.
    Mold is PH sensitive. I suggest you toothbrush and vacuum the dry infestations, learn to live with the remaining discolorations, and apply a light mist of 5% sodium carbonate in water to barely dampen the felt, allow to dry. The trace of residual soduim carbonate inhibits future mold growth.
  15. #14
    Apr 2014
    USA FL
    231
    30
    Look at zerust products. They make a mat that you can cut to size. Zerust products contain volatile corrosion inhibitors, always good to have as an extra help to fight corrosion.
  16. #15
    Mar 2012
    Geilenkirchen, Germany
    2,533
    1484
    1258
    Felt adds no real value other than appearance. It is a moisture attraction and should not be used at all. There are several threads on this subject in the archive. Don't reinvent the wheel. In these threads there is mentioned that there are many variations of felt and some are really nasty corrosion generators.
