Machinistís blocks, 0.5, 0.6, O.7 inch height, purpose?
Results 1 to 8 of 8
    Jun 2016
    Virginia
    926
    478
    111
    Default Machinistís blocks, 0.5, 0.6, O.7 inch height, purpose?
    ffa185c1-15f4-4494-b7e9-c26583798cc3.jpgI won a Kennedy box half-full, at auction. It had been owned by a master machinist who closed his shop. All the Starrett etc. instruments formerly in it were removed and sold separately, so most of remainder were shop-made tools. I have no idea what these blocks were for. I’ve cleaned the drawer and isolated the mystery blocks. There are four configurations of plan view but only three heights, namely very close to 0.500, 0.600, and 0.700 inches height. The side faces aren’t as well-finished as the possibly surface-ground tops and bottoms, so I didn’t bother measuring except one or two on the left which are like 1 x 1.25 inches.
    So most of us are familiar with 1,2,3 and 2,4,6 blocks but are these something similar or what? I’m pretty sure they aren’t shop-made gauge blocks or he wouldn’t have had them kicking around with other hardened things in his K box. Anyone recognize these? 61eb7ac6-6dfc-4eae-9637-78df6d07b57a.jpg
    Oct 2005
    16,029
    I think you just answered your own question "Shop made tools".
  3. Likes Larry Dickman liked this post
    Dec 2008
    New York
    10,234
    2656
    Quote Originally Posted by Cannonmn View Post
    height blocks (sometimes called chucking blocks) are use to support sides (vertical mill) when part in a mill vise so part is clamped on both ends of part.
    if part only clamped on right side of mill vise the left side of part can much more easily move when doing heavy milling. many parts are not simple rectangles and need a chucking block to better clamp both ends of the part in a mill vise. they dont need to be gage block high precision cause mill vise movable jaw can tilt/pivot a .001 or .002" over 6" usually
    if one side of part is wavy from being torch or plasma cut many use a piece of plywood or a tongue depressor or craft stick instead of steel chucking block. the movable vise jaw will compress and the wood will conform to wavy torch cut part shape but the wood will be permanently deformed so its usually a one time use
    custom size steel chucking blocks often are stored for particular parts by the hundreds sometimes thousands of sizes. but if in a vidmar cabinet drawer and sorted by size then often the same chucking block size can be used for many different parts instead a special chucking block only for one particular part
  5. Likes Gordon Heaton, Cannonmn liked this post
  6. #4
    Apr 2004
    Modesto, CA USA
    7,071
    1193
    I think I read that a 5 6 7 triangle is also a right triangle just like the well known 3 4 5 triangle?
    Bill D.
  7. #5
    Jul 2007
    Orlando, Florida
    774
    90
    378
    Quote Originally Posted by Bill D View Post
    Bill D.
    5 6 7 is not a right triangle. Pythagorean theorem.
    CarlBoyd
  8. #6
    Oct 2010
    Oregon
    5,156
    4453
    1876
    Bill D.
    Pythagoras says no. 3*3 + 4*4 = 25 = 5*5, but 5*5 + 6*6 = 61 != 49 = 7*7 .
    If those blocks were in my toolbox, I'd be using them to support stuff up off the drillpress or mill tables when I needed to cut through holes or profile an edge.
  9. Likes Cannonmn liked this post
  10. #7
    Nov 2003
    5,103
    180
    1588
    Yes, just spacers used for set-ups. I have some lengths of flat ground stock that I use in a similar manner. I bought several lengths of it and cut them up into various lengths. Since I wanted four each of several lengths and one piece was not enough, I purchases a couple of pieces of each size. The two pieces differed by a thousandth or two so I marked the ones that came from the same piece of stock with notches on one corner: one notch for the first piece of that size and two notches for the second piece. That way I can match things up as close as possible when need be. These assortments of blocks have been useful many times and they were relatively cheap and easy to make.
  11. Likes Cannonmn liked this post
  12. #8
    Aug 2008
    Sussex, England
    3,407
    12
    752
    I'd have expected 0.800 as well. In conjunction with 1-2-3 blocks that gives you 0.1 increments from 1" to 3.8". mMybe 0.900 too to close the gap.
    Clive
  13. Likes Cannonmn liked this post
