mag drill with reverse?
Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Oct 2003
    East Peoria, IL, USA
    5,385
    337
    786
    Default mag drill with reverse?
    I'm looking for a mag drill that has reverse.
    I have a bunch of m16x2 weld nuts in several assemblies that closed up, got powder coat in them / my hardware is too tight for hand assembly due to it's plating etc...
    I want to run an oversize tap through them. reverse would seem to be handy but they are all through holes and I can simply drop the tap out the back after running through the nut.
    I'm not seeing this as an option on any. are there any that do?
    this one shows a tap being used in it's sales lit but no mention of reverse.
    72721561120, Fein Slugger JMC USA 90 Magnetic Drill | Quality Tools & Accessories
    Dec 2008
    New York
    10,032
    2609
    Quote Originally Posted by dsergison View Post
    usually they have a reverse but i suppose its not guaranteed on every one made. obviously how chuck is mounted effects things. a simple screw on thread mount for chuck would unscrew in reverse. it needs a screw to prevent this just like hand held drills have a screw to prevent chuck unscrewing when in reverse
    Oct 2003
    5,385
    337
    786
    Quote Originally Posted by DMF_TomB View Post
    Really? I have poured over many. Millwaulkee Jancy/Fein, Dewalt, Hougen and I don't see a reverse switch in any spec, picture or manual. Just a magnet on/off and drill on/off and usually a 2 speed shift lever. I've used several but it's been a long time and I don't recall ever seeing reverse.
    Oct 2013
    The Gorge, Oregon
    145
    31
    114
    I went thru same thing. The choices at the time were limited to some Milwaukee’s and Bluerock BRM60A-B, a Chinese knockoff from Amazon. I rolled the dice for knockoff for 30% of the Milwaukee. I ended up drilling 360 1-1/4” holes thru inch plate without a hiccup. The only thing I can not stand is the whine from the gearbox/motor. By the way, the unit came well equipped with a Weldon adaptor, drill chuck (which won’t unscrew in reverse) and tool set.
  5. Likes dsergison liked this post
    Oct 2012
    312
    123
    140
    https://www.amazon.com/KANETEC-KCD-M.../dp/B073X4XTKH
    How about a magnetic base you can use with a hand drill?
    Jan 2007
    Norfolk, UK
    18,608
    14149
    14149
    can you use an auto reversing tapper ?
  8. Likes charlie gary, Ries, digger doug liked this post
  9. #7
    Mar 2005
    Kansas
    7,412
    424
    3394
    I don't see why you can't chase the threads with a tap in a cordless hand drill. Choose a taper tap if you are worried about initial alignment. The rigidity of a mag drill is much more likely to recut the threads off location or at an angle, not to mention the PITA factor of aligning the tap each time.
  10. #8
    Oct 2003
    5,385
    337
    786
    well...maybe if it was just paint removal fine...but at m16x2 size it's a hell of a lot of torque far beyond what you want to use on a cordless drill or your wrists if your re-cutting metal.
    We already did it with a normal size tap trying to chase out the powdercoat and that's when we found the nuts were quite undersize. It was Very hard going. Myself I did pretty well but not great. The ones a coworker did, well he can't hold a drill straight. It was a spiral point tap we had and it would constantly jam and cock sideways on removal.
    The results were far less than awesome. Some of the welds nuts were apparently less than perfectly perpendicular to the plates and the chased threads still would not accept our overly heavily plated hardware.
    I now have an oversize taper tap. I expect even more force recutting these, and the previously buggered threads I wish to recut very straight not just let it self align.
    I'm looking at making a guide and driving the tap through all 100 holes by hand but then I though a mag drill would be perfect.
    if I used it for tapping I think would make or buy a weldon shank tap driver and make a weldon shank alignment alignment nub so I could center the spindle with the short nub then raise the spindle and insert the tap and then drive it.
  11. #9
    Nov 2004
    Webster Groves, MO
    7,183
    1801
    3259
    I just put a reversing switch on a mag drill. When I reverse it without letting it come to a stop, I get a big blue flash from the brushes. I am now working on a current limiter to keep from frying them. I'll keep you posted.
    Bill
  12. #10
    Mar 2004
    Edison Washington USA
    10,321
    964
    5322
    I have a friend who just bought one of these- a hefty metabo drill made to tap- it has auto reverse. He tapped a couple thousand holes in thick steel with it recently, he loves it.
    Its a lot quicker to use this than to position a mag drill for every hole.
    I have done my time wrassling with mag drills.
    When you need em, you need em, but I think its overkill for this, and they dont have a clutch or auto reverse.
    they say it will tap up to M12.
    My buddy says it has a lot of torque.
    GB 18 LTX BL Q I (603827890) Cordless Tappers | Metabo Power Tools
  13. #11
    Oct 2013
    The Gorge, Oregon
    145
    31
    114
    What’s kinda cool about that Metabo is that it has a 4 sided chuck to grip the tap. Price ~$690......
  14. #12
    Nov 2017
    Kansas
    277
    65
    123
    Every Milwaukee I have ever used had reverse. You can leave the clamp between the drill and mag loose to ease alignment. I'd try a right angle drill. The kind electricians use for drilling studs.
  15. Likes Toolznthings liked this post
  16. #13
    Jul 2009
    Peoria, IL
    11,698
    50
    8950
    I've chased thousands of 1/2-13 threads after powder coat with a regular cordless drill and a spiral point tap.
  17. #14
    Oct 2005
    14,547
    A tapmatic head is pretty small, will one fit ?
  18. #15
    Mar 2013
    Washington
    280
    136
    191
    Old sawmill/millwrigh trick is to press a nylock on to the back of a tap and drive it with a air impact gun
    Git er done!
  19. #16
    Jul 2009
    Peoria, IL
    11,698
    50
    8950
    They make tap sockets...
  20. Likes moonlight machine liked this post
  21. #17
    Nov 2007
    marysville ohio
    9,262
    2643
    6123
    Quote Originally Posted by ewlsey View Post
    My Milwaukee magnetic drill has reverse, I don't think I have ever seen one without reverse.
  22. #18
    Mar 2013
    Washington
    280
    136
    191
    Yup and 12 point sockets work to but..
  23. #19
    Jul 2009
    Peoria, IL
    11,698
    50
    8950
    Quote Originally Posted by Hbjj View Post
    But jamming a nut on the tap is better?
    When I hear "old millwright's trick" I just shake my head. Probably from the years I've spent cleaning up after those guys. All of their tricks involve a hammer...
  24. Likes Ries, Mtndew liked this post
  25. #20
    Oct 2013
    st,louis mo
    658
    341
    Mine is an old school .it has a mechanical reverse. You rotate the upper brush holder and it changes the direction of the motor. Supposedly this is a superior design electrically speaking. This also prevents an accidental instant reverse which is quite a spark show on these big drills
