magnetic table- alternate uses?
Results 1 to 13 of 13
    Jun 2007
    Vancouver Island, B.C. Canada
    1,829
    46
    208
    Default magnetic table- alternate uses?
    I have a small mag table from a scrapped surface grinder.
    What kinds of things can be done with it other than holding parts for surface grinding?
    Anybody done something quite unusual and want to share?
    Hopefully this info could be useful to anyone with a mag table sitting around not getting used.....
    I recently acquired a CNC mill and wondered if there ever was a job that could be done with the mag table. I can't see it holding any part well enough but I just don't know.
    Thanks for the replies.
    Mar 2019
    UNITED KINGDOM
    187
    35
    I’ve used them on the mill for large plates, used on my bench for polishing, used them on the spark eroders, flat and up at 90 degrees.
  3. Likes Laurentian liked this post
    Apr 2018
    3,719
    1681
    You could mount it to the wall in the kitchen and use it for storing cast iron frying pans ...
  5. Likes Laurentian, metal-ica, Spartan094 liked this post
  6. #4
    Aug 2004
    Virginia
    2,403
    179
    950
    I have an old one that came off a surface grinder. I use it for welding setups. It holds everything in place very nicely so you can tack your whatsiz together.
  7. Likes gbent, Laurentian, Red James liked this post
  8. #5
    Mar 2005
    Kansas
    7,697
    459
    3618
    I have used a small mag chuck on both a manual and cnc mill many times. The cnc jobs had fixture plates with pins to stop sliding. Fixture design takes thought to avoid trapping chips.
  9. Likes Laurentian, 9100 liked this post
  10. #6
    Jun 2012
    Michigan
    4,973
    4532
    2996
    You could use it to hold odd shape parts for inspection purposes.
  11. #7
    Jun 2007
    1,829
    46
    208
    Luke,
    When you say “large plates” what size range is large?
    GBent,
    Got any photo’s of those setups or fixture plates?
    Thanks for the replies all....well except for the frying pan reply.
  12. #8
    Jul 2006
    rochester, ny
    1,960
    408
    561
    How does the holding force of a mag chuck compare to a vacuum chuck? Theoretical max for vac is 14.5 psi, usually less in practice.
  13. #9
    Jul 2007
    UNITED KINGDOM
    4,930
    2729
    2404
    With mild steel that's at least as thick as the pole piece separation, you should be able to get 60N/cm^2 or better. That's a bit more than 85psi.
  14. Likes Laurentian liked this post
  15. #10
    Jun 2007
    1,829
    46
    208
    Mark,
    Thanks for that info, Richard asked an excellent question.
  16. #11
    Dec 2016
    Arizona
    207
    77
    98
    They work well for slag removal and sanding on sheet metal parts with an angle grinder. I have seen places keep one by their plasma table for that purpose.
  17. #12
    Jun 2007
    1,829
    46
    208
    John,
    That is a usage that I did not consider but of course would work very well. Unobstructed access to all four edges definitely speeds things.
  18. #13
    Apr 2015
    Ohio
    21
    I used a lever type mag chuck on a surface grinder to hold a tapered gib still while scraping, the work light on the machine was also helpful.
