make a bushing
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: make a bushing
    Aug 2007
    michigan
    554
    8
    Default make a bushing
    I have to make up a couple of bushings for a lawn roller, I want brass or some metal that will wear and not wear the steel down. I plan to put fittings in it and grease it often.
    I did some looking into this and they said SAE 660 Bronze would be good. I would like it to last some time with lots of grease and not not damage the steal.
    Another said that Oil-lite brass or bronze would be good for this?
    Thanks for any ideas on this.
    ben 80
    Nov 2014
    Florida
    6,209
    2463
    3085
    Yep, oil-lite would be a good choice. If your shaft is a nominal/standard you can buy to size too, no machining required (well maybe cutting to length).
    McMaster-Carr
    McMaster-Carr
    Oct 2020
    Missouri
    24
    48
    Aluminum bronze if you're dead set on making from scratch. Can just buy a similar oil-lite bushing
    Aug 2007
    michigan
    554
    8
    I will go to the local , metal shop and see what they have. I don't mind the machining part, will have to do some. It always comes to this, ya buy cheap, ya get cheap. But I can fix it.
    thanks
    Sep 2010
    Oklahoma City, OK
    5,463
    1051
    2378
    It may behoove one to pay some attention to the shaft as well. Its condition also has an impact on the bushing's life.
  6. Likes Gordon Heaton liked this post
    Nov 2019
    CANADA
    Ontario
    555
    848
    130
    local Tractor supply will have bearing bronze bushings
    Feb 2010
    IN, USA
    298
    9
    323
    I'd be surprised if you can't buy what you want from McMaster Carr. The only bronze bushing I've ever had to make is one for a WWII era airplane that called for a special alloy. The size was readily available for a few dollars from McMaster and probably would have outlasted the plane, but when working on aircraft you don't make material substitutions. For a lawn roller? No way I'd waste time making something I can buy with the loose change in my pocket.
  9. Likes digger doug liked this post
  10. #8
    Aug 2007
    michigan
    554
    8
    I am a retired machines of 40 years, making auto parts and set up a hobby machine shop in the basement. Its a full shop, I was making so much money with OT I could afford it.
    Keeps me tied to my roots and helps me with hobby’s , etc. Don’t mind fixing my blunder ,buying metal to fix this. LOL
    I am going to McMaster Carr and ordering the metal.
    Thanks for all the info, you guys are great.
    ben
  11. #9
    Aug 2007
    michigan
    554
    8
    I forgot to ment6ion, its a 900 lb roller, I do part time mowing, etc and rolling helps me get the jobs done quicker.
    I ordered the SAE 660 from McMaster Carr, price was not too bad and it won’t take much to finish. I got it with the 1 in. bore, no drilling.
    Thanks again
    ben
  12. #10
    Nov 2019
    CANADA
    Ontario
    555
    848
    130
    my 1400 lb roller only uses 1" pillowblock bearings
  13. #11
    Mar 2005
    Kansas
    8,528
    588
    4278
    While it seems a little backward, the bearings are to support the pull frame, not the roller. Not much actual load.
  14. #12
    Aug 2007
    michigan
    554
    8
    These are to bearing to pull the load. The draw bars go on them. I would guess a reg. load of 450lb. each , with max up to 600 to maybe 800 lb. when loading etc.
    The rods that the bearing go on , is hollow tub steel. I am going to have to put a solid steel rod thru it.
    Not sure what kind of steel would best, any idea's???
    ben
  15. #13
    Oct 2005
    21,401
    I've seen everything from simple steel pipe bearings with maybe a grease zerk, all the way
    up to brake disc rotors and axles on these things.
    It this for commercial, landscaper usage ? or "Once every springtime" ?
  16. #14
    Aug 2012
    California, Central Coast
    5,159
    2376
    2127
    Use 1" cold roll bar, it should work as is in the 1" bore of your bronze. Just a slight polish, if anything to make it a really nice fit.
    Any steel you have on hand would also work.
  17. #15
    Nov 2019
    CANADA
    Ontario
    555
    848
    130
    the bearings dont support anything, even rolling load is only 10-20% of total weight. I just used 1" solid all the way through the middle.
  18. #16
    Aug 2007
    michigan
    554
    8
    ya, its commercial, but just part time, a little extra money and it will help with my mowing ( faster mowing more profit).
    I will put the cold roll steel , down the center. The brass bearings and the steel in the hollow steel , should make it last a little longer.
    Thanks for all the help
    ben80
  19. #17
    Jul 2005
    Cottage Grove, MN 55016
    8,356
    4392
    4903
    These guys sell individual bushings and oil-lite bearings. www.gobeilco.com
  20. #18
    Jun 2001
    lancaster,ohio.43130
    956
    21
    149
    Not that I am too anal about things, I use a 48" deck on a riding mower and got tired of rebuilding the shaft and rollers. So this winter I rebuilt the shaft with a piece of 4140 PH. The rollers were made out of UHMW. I made a clamp that tightens with a bolt so that just unloosen the bolt and it all slides off. We will see who wins this round.
  21. #19
    Oct 2005
    21,401
    Quote Originally Posted by mark costello View Post
    Is there a chance that the steel shaft is rusting in the off season ?
  22. #20
    Jun 2001
    956
    21
    149
    It is in a heated garage so I would not expect more than light surface rust.
