Making a Depth Micrometer Rod anyone make one ?
Results 1 to 17 of 17
    Apr 2009
    Beaver County Alb. Canada
    1,850
    533
    906
    Default Making a Depth Micrometer Rod anyone make one ?
    Im missing a rod for a set and was just pondering trying and making one .
    Drill rod, thread the end make some nuts and then using guage blocks set it up. Im retired and not using it for a living so I dont see why not!
    Tell me why I shouldnt. Thanks
    Aug 2004
    Centerville,OH
    2,149
    84
    Give some dimensions of the rod you're missing. What brand is the mic?
    Apr 2009
    1,850
    533
    906
    I’ve already posted it in the want adds to no avail. It’s a 440 Starrett
    Missing the 5-6 rod .125 dia
    Jun 2006
    Alabama
    1,872
    1085
    735
    Go Fer It!
    I wouldn't expect better than +/- .002" if you don't have a grinder to make the face perpendicular to the shaft.
    Might be a good learning experience either way.
    Jul 2008
    Ontario, Canada
    257
    6
    85
    Quote Originally Posted by Rstewart View Post
    Go Fer It!
    If you give me a lathe or mill, some duct tape and a rotary tool I'll get it flat enough you can't tell otherwise. Of course, you could make up a proper clamp and call it a toolpost grinder or a high speed auxilliary spindle, but what's the fun in that?
    Mar 2014
    Nebraska
    344
    42
    216
    Why? One can be had from MSC for under 20 bucks.
    5 to 6 Inch, Micrometer Rod 86417243 - MSC
    Jun 2012
    Eastern PA
    930
    230
    412
    Be aware that the Starrett rod at MSC may or may not be the right length for the OPs 440. The rods for my 440A are very different than the one she measured for his 440.
    Jan 2002
    West Coast, USA
    7,684
    474
    5107
    I've done it -- and easily.
    Buy some drill rod in the right diameter. Cut to length and thread an end. Thread isn't especially critical -- just there to adjust. You"ll likely have to turn the adjusting nuts down a bit to fit inside the cap.
    Whether you harden the end is up to you. A 6" depth rod might not get used enough to be worth the slight effort. Make a lapping block (close fitting hole). I used diamond stones to get mine flat, then shiny flat. The block keeps the end at 90 degrees.
    From there your accuracy is all in the adjustment. No reason it shouldn't be better than .001".
    While you're at it, might as well make a 7" depth rod from the same stock. Or just save a long piece, already threaded for whatever strange depth measurement task the future might see. Just minutes to whack it off to length, polish the end, and adjust.
    If you have truly accurate 1-2-3 blocks, a couple of them stacked make a good setup for adjusting your 6" rod. Sadly, you'll need to check -- the cheap blocks and even some of today's brand names aren't made to tenths (or even thousandths) -- just gang-ground to match.
  9. Likes mister honey, dgfoster liked this post
  10. #9
    Apr 2009
    1,850
    533
    906
    Thanks to all. Some good ideas.
  11. #10
    May 2003
    Iowa
    10,492
    3616
    4270
    I've made several rods for my depth mike. All started with ejector pins. Just find the local mold makers.
    JR
  12. Likes awander liked this post
  13. #11
    Mar 2004
    Princeton, NJ USA
    1,823
    1493
    421
    Just saw this. I have a few rods in a toolbox. No idea of the brand and lengths, I can check later when home from work.
  14. #12
    Jun 2012
    Eastern PA
    930
    230
    412
    Quote Originally Posted by JRIowa View Post
    JR
    Thanks for that, JR. I have a pile of ejector pins here, and I do need a longer rod for one of my depth mics....
  15. #13
    Sep 2013
    Ohio
    346
    196
    176
    I agree 100% with JR. They are very easy to make out of ejector pins with a v-block on a surface grinder. I made a complete set of 0-6" that are tapered for depth check of tapered ribs on molds. I just blued up the ends and ground the taper until there was about .030" of blueing left on the end. I didn't want to go to an extreme sharp tip due to damage/accuracy issues. They come in very handy.
  16. #14
    Apr 2009
    1,850
    533
    906
    Quote Originally Posted by sandiapaul View Post
    Length is 9.165 / Dia. is .125 / Across nuts is .215
  17. #15
    Apr 2009
    1,850
    533
    906
    JR
    No mold makers here , but thanks.
  18. #16
    Mar 2004
    Princeton, NJ USA
    1,823
    1493
    421
    Sorry no 5-6" in my collection
  19. #17
    Apr 2009
    1,850
    533
    906
    Thanks anyways.
  20. Likes sandiapaul liked this post
