Making gears
Likes Likes:  0
Results 1 to 12 of 12
Thread: Making gears
    Dec 2009
    Wyoming, USA
    40
    Default Making gears
    Hi I am somewhat new to the forum, so please forgive my ignorance.
    I would like to make a set of gears for my lathe.
    I got the pitch of the gears from someone on the internet who had done this before. Pitch is 24.
    Not sure what this pitch means. Is it diametral ptich or pitch diamater?
    I am pretty sure it is the dametral.
    Thanks for any help you can provide.
    Aug 2004
    Virginia
    2,162
    169
    757
    That's a tall order there partner. I have made some gears out of necessity but It is not for the faint of heart. You might want to consider buying some on Ebay or something until you get more experience. Just my two cents worth.
    Sep 2007
    Washington
    5,040
    153
    1409
    May I humbly suggest you take a read through this book:
    http://www.amazon.com/Gears-Gear-Cut.../dp/0852429118
    It will bring you up-to-speed on gear cutting. This book was a great help to me when I started out cutting my own gears.
    There is quite a bit to it. Straight spur gears are pretty easy, but even there, you have to mind a good number of parameters and principles.
    To answer your immediate question, 24 is most likely the diametral pitch, which describes how many involute teeth are to fit on a 1" diameter pitch circle.
    Regards.
    Finegrain
    Dec 2009
    South Yorkshire, England.
    368
    556
    28
    I would agree with Finegrain's book suggestion. I have a copy of this volume which is written especially for the amateur to encourage him to 'have a go' in his backyard workshop. It contains a lot of valuable information and pictures of Myford Super 7 and Dore Westbury miller setups. I haven't bitten the bullet yet, but now have the dividing head and have made the arbor for the cutters so it is only a matter of time..........
    Kind regards
    Steve
    Dec 2009
    Wyoming, USA
    40
    Default Thanks for info
    I just orered the book that was suggested.
    I have an idea of how I want to cut these spur gears using mill and dividing head. Just need the calculations to obtain the right size OD.
    Nov 2007
    Wales
    121
    This might help, be sure to click the link when you get there
    http://madmodder.net/index.php?topic...28357#msg28357
    Also have a good look around that thread as well ...
    Aug 2003
    port allen, louisiana usa
    1,553
    365
    333
    Talking gear cutting
    Quote Originally Posted by Jdaniel343 View Post
    Hello: If this is a spur gear: It has been awhile but:
    D= number of teeth +2 divided by the dp as I recall.. In your case dp is 24..
    Now if the gear you want to cut is helical, then that is a bird of a different feather...
    Mike
    May 2009
    Canandaigua, NY, USA
    2,711
    126
    1137
    It's not that difficult. Once you know the OD, and buy the right cutter for the number of teeth, the cutter will have the plunge depth printed right on it. The biggest problem is not messing up when turning the crank on the dividing head. The first time I cut a gear, it was "wow, I'm cutting a gear" for the first ten teeth. After about 50 it gets kind of tedious. After 120 or so, buying them looks better and better. BTW, I've cut many Delrin gears for my lathe. They work great, are plenty durable, don't wear out the cutters and are much easier then steel or cast iron.
    CH
    Feb 2008
    Orange County, CA
    243
    42
    62
    Just ran into that on my old LeBlonde, LeBlonde wanted close to 300.00
    for a new gear. Al quoted me 200, I sent him the gear to duplicate, haven't seen it yet, but he seemed very nice and helpful over the phone. For 200 bucks no way I would take the time to try and make it.
    http://gearsmade.com/
    Dec 2006
    NJ
    1,864
    283
    445
    Quote Originally Posted by Steve's Hobby View Post
    I had no idea "Al was so close to me ...could almost throw a stone to each other.
    Jay
    www.CandLMachine.com
  11. #11
    Jul 2004
    Houston, TX USA
    28,751
    To elaborate on what Mike (ramsay1) wrote:
    A 24 tooth 24 DP gear will be 26 divided by 24 or 1.083" OD
    A 100 tooth 24 DP gear will be 102 divided by 24 or 4.250" OD
    John Oder
  12. #12
    Aug 2003
    1,553
    365
    333
    Hello: I made a set of gears for my 1940 LeBlond 15"..
    Both were cluster gears so had to cut one gear, the large one then cut the smaller one and press on then set with setscrews on the parting line..
    I cut all of these spur gears with my K&T 2hl with a mod H dividing head.. Mike
