Making my own handwheel collet closer - material question
Kevin T
Stainless
Jan 26, 2019
I want a 5C collet closer for my 1941 16" lathe and it looks like a great project for me. I bought a prefab threaded tube and am planning on finishing it off myself by turning a shoulder and a handle. I am not very experienced with my lathe yet I just got it going recently but I am even more green when it comes to material selection.
Does anyone have recomendations for me on a relatively free machining material (semi rust resistant) that would be good as the indexing shoulder of the assembly? So far I have only dabbled with a couple operations w/cast material.
12L14 rusts just looking at it! I used plain old 1018 mild steel when I made closer's for both of my lathes. Bought thrust bearing and washers from McM/C ,also made my own draw tube out of DOM tube.
Same here. Scrap yard tube, Whatever was laying around for the shoulder, hand wheel a 1/4" aluminum disc with an oak outer edge riveted on with brass rivets. No thrust bearing just a bit of moly grease now and then.
Works very well and has lasted a long time. Cost...Zilch........Bob
Off cut / drop box for the tube, scrapped Alu wheel ''thingy'' from a customers scrap skip, Loctited assembly with a nylon washer.
Nice, I am thinking about a wood outer also. I havent seen a thrust as part of the stock ones for sale for my era lathe.
I saw this one that I liked.
Shouldn't there be bearing where the drawbar snugs up against spindle on the left side of the headstock? Seems like it would be useful. My Stark #4 has one.
I dont think so unless this is more sophisticated that I am led to beleive.
there is a thrust bearing in that, hence the oil hole here;
the collar with the oil hole rotates independently of the tube on a thrust bearing.
thats from a 16 also, but I'm intending to trim it down to fit a 10L I have for sale. I have the original hand wheel, the shop it came out of had turned a larger wooden one for it, but I found the original on a dusty shelf. untouched since about 1952 I'd guess.
actually, anyone have a draw tube for a wartime production 10L they want to swap for a 16? that would save us both some hassle.. SBlatheman..? depends on your stock and what folks want.. let me know. cheers!
(P.S. I've got the thread protector for the nose of a 16 and would throw that in..)
i would abandon the large diameter "wheel" in favor of a smaller diameter piece turned from the solid with some tommy bar holes in the periphery.
but thats just me. :)
That’s the stock part. I don’t know enough to say they are all like that, but I didn’t modify it, and the shop it came out of almost certainly didn’t either.
(One more reason to just buy the stock drawbar..save a lot more in time than you have sunk in materials, unless you have nothing much else to do... )
