Michael Moore
Titanium
- Jun 4, 2004
- San Francisco, CA
Drill rod appears to come in lots of useful fractional sizes and to have a nice surface finish. This makes it look attractive for use in spindles (for example motorcycle axles) where all you want to do is just put a thread on each end for a nut, or maybe a thread on one end and a welded boss on the other, and then slide it into a standard bearing.
I've looked in the tool steel section of Machinerys Handbook but that appears to be largely concerned with the property of the steels after hardening, and doesn't make it clear to me how appropriate it might be to use the steel in "as supplied" un-hardened condition. I also seem to run into a "too much information" situation where I don't have the background to evaluate all of what I'm being told.
Is it safe to use something like O1 oil-hardening drill rod as a structural part? If you weld something to one end of the oil-hardening steel and let it slowly air cool will it get harder/more brittle and prone to fracturing, or is that not going to be an issue if you avoid the air-hardening steels?
Or should I just be looking at turning things out of annealed or pre-hard 4140 instead which I'm pretty sure is suitable for the parts I'd be interested in making? The 4140 doesn't seem to be as readily available in all the handy fractional sizes though.
cheers,
Michael
cheers,
Michael
