making a square hole in round bar?
Results 1 to 18 of 18
    Dec 2013
    montana
    363
    42
    89
    Default making a square hole in round bar?
    I was wondering what is the best way to have a 30mm square hole cut out of a piece of 3" round bar that is 4" long. I was thinking the easiest way is to have someone with a wire edm cut it out.
    I am making a lower tool holder my Trumpf nibbler that im using for doing some car panel shaping with. The top holder uses 30mm square bar but the lower is set up for a round tool holder. I figured if i make a new lower that uses the same size tool holder as the upper, it would be a lot easier to make tooling and line things up.
    Ill add a picture of the current lower tool holder, some tooing and that should give and idea of what Im looking to do. If there is any better ideas than cutting it with and EDM let me know. The rest of the machining is east to do, it just the square hole i cant make. Ill have to send it out some place since there is no one around here that does that kind of work so if there is some good places of if anyone on the form does that, please let me know.
    thanks
    Apr 2004
    Modesto, CA USA
    8,073
    1491
    I think that is too deep for rotary broaching. Does the square go all the way through? so a shaper could do it?
    Bill D
    Sep 2010
    Oklahoma City, OK
    5,288
    976
    2278
    Depends on how sharp the corners need to be. Drilling progressively larger holes to relieve the corners then milling out the bulk could get you pretty close.
    Or relieve the corners entirely. Or drill a big hole and fix some pads in it.
    Lotta ways to skin this cat that don't involved a wire machine.
    Sent via CNC 88HS
  4. Likes BT Fabrication liked this post
    Apr 2008
    Helmer, Indiana, USA
    1,251
    341
    508
    Wire is the best way, but it is slow and expensive. Can you make it in two pieces and then weld it together? Leave the OD oversize for a final turn op after welding.
    Dec 2013
    montana
    363
    42
    89
    Quote Originally Posted by Bill D View Post
    Bill D
    ya the hole goes all the way through. never though about a shaper, that is something i might be able to find around here.
    Dec 2013
    montana
    363
    42
    89
    Quote Originally Posted by Kyle Smith View Post
    I though about making it in 2 pieces and welding them back together, i was just trying to save some time. I was also looking at trying to find a square broach but didnt find anything.
    Dec 2013
    montana
    363
    42
    89
    I think ill just put it in the lathe and drill out the bulk of the material i need to remove, once that is done i will split the round bar in half and mill the slot out so i have square corners then weld it back together.
  9. Likes Newman109 liked this post
  10. #8
    Mar 2004
    Edison Washington USA
    10,646
    1064
    5735
    I have made square holes, and splined holes, simply by drilling out the center, drilling small holes at the four corners, and filing the material. Takes a while, but the old armstrong method works just fine.
    German apprentices used to have to file a perfect cube, then, when it passed, file it into a perfect sphere.
    Filing isnt particularly hard, and its pretty hard to ruin it by going to far...
  11. #9
    Jan 2011
    Fairfield, PA
    444
    234
    226
    You can by sleeves with square holes. These are inch:
    Green Bay Manufacturing
    Perhaps metric is available as custom or elsewhere?
    Bill
  12. Likes boslab, AlfaGTA liked this post
  13. #10
    Apr 2004
    Modesto, CA USA
    8,073
    1491
    I would drill four small holes in each corner then one big one centered on the desired square. Then use a keyway broach four times.
    Bill D
  14. #11
    Nov 2003
    5,606
    194
    1900
    I was going to suggest that. I have a chuck wrench with a square hole. It was made by milling a slot from the side of the round stock and then a (rectangular?) piece was brazed into it to form the fourth side. In my case the end of that rectangular plug was rounded to the radius of the milling cutter, but you would not need that if the hole goes all the way through. The OD was probably finished after that. You have to look close to see the joint. If you have enough meat between the square hole and the OD, it will be almost as strong as the original steel.
    Brazing would produce less distortion than welding and with full penetration of the braze into the crack, it will probably be as strong or stronger than a weld unless a lot of care is taken.
    Quote Originally Posted by climb-101 View Post
  15. #12
    Mar 2011
    SWITZERLAND
    1,051
    126
    432
    Got files?
  16. Likes Bobw liked this post
  17. #13
    Jan 2007
    wales.uk
    1,340
    198
    242
    Cut bar in half, mill slot in both halves (longitudinal cut in half!) bolt back together or weld or whatever, I’m sure I’ve bought off the shelf bolster blanks years ago, I think they were flame cut or water jetted
    Mark
  18. #14
    Apr 2018
    6,027
    2889
    I dunno about you guys ... if this isn't a perfect excuse to buy a 6" Pratt & Whitney slotter, I'll be a blue-nosed gopher.
  19. Likes climb-101, TeachMePlease, AlfaGTA liked this post
  20. #15
    Nov 2019
    CANADA
    Ontario
    282
    346
    50
    Quote Originally Posted by Cole2534 View Post
    Sent via CNC 88HS
    yep this is the best way, mickey mouse ear the corners. not like they do much anyways unless its a die for stamping.
  21. #16
    Apr 2007
    South Carolina
    47
    11
    Believe Kyle has got it right
  22. #17
    Jan 2016
    New York
    268
    6
    73
    Default Make a broch
    Bill D
    In addition "Bore" a hole the size of the square broach. Make your O1 60-62Rc square broach with a round pilot the size of the hole on the front of the broach. Undercut the pilot to allow clearance for the chips from broaching. Make your work pieces in one inch thick sections. Then screw and dowel together after broaching the four sections using the broach to align the sections. Use oil. Broach the openings in a press a very short distance at a time, remove the broach and file to clean out the scrap. Then repeat until finished. If greater accuracy is required make two broaches. One .002 undersize. One on size. Takes a little time but you can do this in your own shop.
    The broach is nothing more than a square with a pilot on the end.
    All The Best
    Roger
  23. Likes climb-101 liked this post
  24. #18
    Jul 2007
    Missoula Mt
    795
    28
    323
    Easy to do on a slotter...Phil
  25. Likes climb-101 liked this post
