JohnnyJohnsoninWI
Hot Rolled
- Dec 9, 2003
- North Freedom, WI, USA
Let's say I wanted to make a new spindle for something like the workhead on a cincinnati #2 tool and cutter grinder or a cincinnati monoset grinder. Obviously, I would obtain the appropriate raw materials, rough it out on a lathe, then send it out for heat treat. Once it comes back, how would I grind the bearing journals and internal taper on one or both ends?
Assuming you had a cylindrical grinder capable of such an operation. I think it would be best to grind the journals and the taper all in one set-up (ie. one chucking) on the machine. That way you'd be concentric within the accuracy limits of the cylindrical grinder. However, I don't know how you could hold the workpiece so that grinding all those surfaces are possible without rechucking.
Possibly, the journals are ground and the spindle is assembled into a workhead, then the internal tapers are ground while the spindle turns on it's own bearings?
It seams to me that any other approach would be a struggle to minimize concentricity and parallelism on the rotational axis?
How do the manufactures do it and how do the rebuilders do it?
John
John
