Manley Hydraulic press weight ?
Likes Likes:  0
Results 1 to 4 of 4
    Oct 2005
    Pittsburgh, PA
    1,843
    169
    Default Manley Hydraulic press weight ?
    Hi
    I'm looking for a weight for a model 921-B Manley press 60 ton. This one did not have the arbor press on the side or test centers but is an air over hydraulic as well as manual pump. Not sure how wide it is but I think it is the wider model.
    I found a few manuals on line but don't see a weight listed. Just an approximation is fine.
    Andy
    Aug 2015
    Illinois
    1,526
    1133
    653
    Check on Dake presses. They may have a similar capacity press and may publish weights.
    Mar 2005
    Kansas
    8,069
    505
    3887
    I have a 75 ton Dake. The trucking company weighed it at 915 lb on its way here.
    Oct 2005
    Pittsburgh, PA
    1,843
    169
    Thanks guys
    The Dakes look close enough for my needs. Think I will call it 1500 lb at the max end.
    Andy
