Manual Lathe - Parting Threads - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21
    Oct 2010
    Dewees Texas
    3,198
    35
    1060
    You attached photos of your finished part earlier. Is it the piece that is held in the collet or the piece that falls free during cutoff? If in the collet it is entirely practical to use one tool to cut off and chamfer. If the part is the one that falls free I would chamfer and cut off separately.
  2. #22
    May 2021
    Indiana
    9
    6
    The part remains in the collet.
  3. #23
    Oct 2010
    Dewees Texas
    3,198
    35
    1060
    Makes it fairly easy to grind one tool to cut off and chamfer. The 2 edges will not wear at the same rate so a tool that does one diameter can do a smaller diameter as it gets worn and resharpened. In the long run doing it with a push pull set up will be better and faster. Another plus on the finished part being in the collet is if your tool is on center you will have no cutoff tit to debur later.
  4. Likes Brian.M liked this post
  5. #24
    Mar 2009
    6,118
    116
    1201
    I do what you do but have an alternate way of holding the thread screw. I cut a disk and thread a hole in the center. Screw the thread from the back and hold with a nut.
    That way I don't have to remove the collet for every screw that has a head on the opposite end. I use a 30 degree angle and lightly touch with my favorite triangular file.
    If I was doing a ton of them then I would grind a wide enough parting tool to cut-off and bevel the end at the same time.
  6. Likes Brian.M liked this post
