I called around at my pals place today and borrowed his handbook for the old " Herbert 4 lathe " he had. It has a lot to say about headstock oils that I can't be bothered repeating. The gist of it is this - " Oil for Headstocks, Feed Boxes, and for general lubrication of machine tools should contain pure mineral base oil with no vegetable or animal oil and no form of soap or solid matter such has graphite, in suspension.
The viscosity of the oil as registered by a No 1 Redwood Viscometer should be between 1,000 and 1,300 seconds at 60 degrees F or between 650 and 900 seconds at 70 degrees F "
" The following is a typical specification of the oil suitable for machine tool lubrication -
Specific Gravity at 60 degrees C----------- 0.920 to 0.935.
Redwood No 1 Viscosity at 70 F-----------650 to 900 secs.
Redwood No 1 Viscosity at 140 F----------100 secs.
Redwood No 1 Viscosity at 200 F----------45 secs.
Closed Flash Point--------------------------360 F.
Pour Point-----------------------------------10 F.
Free Fatty Acid----------------------------- Nil.
Ash -----------------------------------------Trace.
We recommend and use " Circol " headstock oil for use in all our headstocks and feed boxes etc . "
That's it guys, pick the bones out of that ! I must say " Circol " doesn't ring any bells with me.
To be honest I can't see how the oil level will be tripping out the electrics on your lathe unless it's completely empty and on the verge of seizing up. I don't recall an electrical low level switch on my pals lathe, just a gallery type sight glass on top of the headstock. I do remember the flow through the sight glass being very substantial though.
Regards Tyrone.
