Which Material Cannot be welded by gas?
Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Jul 2019
    UNITED ARAB EMIRATES
    13
    Default Which Material Cannot be welded by gas?
    As a newbie of welding, I just want to know which Material Cannot be welded by gas?
    Jan 2019
    Tennessee
    405
    123
    109
    Quote Originally Posted by monu96 View Post
    stainless, ti, al, high zinc brass (well, can be...but), si bronze if you are new at it is tricky, corten, copper (see bronze), many more I am sure.
    stick with steel, most flavors, to start. Steel is forgiving by nature. no flux, forgives to much/to little o2, flows alright, likes to flow to joint and not away from joint.
    Oct 2005
    14,344
    Same answer as the others....crack a "Book" and do your own homework,
    not have others write it for you.
  4. Likes Mtndew, ManicMetalBasher liked this post
    Apr 2007
    Melbourne Australia
    188
    30
    19
    I never could get my woodcraft filler to flow, hardwood, softwood, reducing or carburising flame. All went up in smoke.
  6. Likes tdmidget liked this post
  7. #5
    Nov 2013
    Eastern Massachusetts, USA
    3,907
    4275
    4124
    I've never tried these but this outfit sell fluxes for gas welding Stainless Steel, Cast Iron, Aluminum, and Copper.
    Welding Flux - TM Technologies
    Edit: Thinking back (waaay back) we did weld cast iron in school as part of welding training. I can't remember if we used flux or not. We used cast filler sticks and used firebricks and a pre-heat prior to welding.
  8. Likes memphisjed liked this post
  9. #6
    Mar 2006
    New Jersey
    1,082
    13
    290
    The TM Technologies website above has a very helpful tech section on various methods. Aircraft Aluminum welding I believe is still required to be gas.
  10. #7
    Jan 2019
    Tennessee
    405
    123
    109
    Quote Originally Posted by Kenre View Post
    elmors flux with a super whisper flame with quick movement works.
  11. Likes Kenre liked this post
  12. #8
    Dec 2008
    New York
    10,029
    2604
    oxyacetylene cannot be used on reactive metals like titanium and magnesium would be a fire hazard even if you had a flux. oxyacetylene requires massive amounts of heat when thickness is over 1/4" and especially when fillet welding a tee joint.
    tig or tungsten inert gas torch using a arc and usually argon gas is far more efficient. compressed gas is not cheap. if you got enough amps you can tig weld 3/4" thick steel maybe putting down a 1/4" weld and easily weld 2 to 10" per minute. oxyacetylene torch would requires a large flame not only do you have to worry about heat rising shattering electric light bulbs by the ceiling but the cost of acetylene is expensive and it is extremely slow to weld.
    its 10x easier to make smaller welds with a tig torch and get less warpage. even if material is 3/4" thick there are times where you want small 1/4" welds to get less part warpage.
    if you put down 100 lbs of weld per year the cost to do by oxyacetylene would be far more expensive than if you bought a tig torch setup and welder and used argon shielding gas. i dont have exact figures but if its
    over $3000. for oxygen and acetylene and filler metal and takes 100 hours to make 100 lbs of weld or
    $2000 for tig setup and machine and argon gas and filler metal and takes 30 hours to make 100lbs of weld
    .....just saying it can be cheaper and faster to get better welding equipment especially if you track costs and labor hours required per year
  13. #9
    Oct 2009
    Louisville, KY, USA
    920
    213
    203
    I think you're asking the wrong question. Figure it what you're going to be welding and get the right equipment.
    The good news is that if you learn OA welding then TIG is easy and fun in comparison.
    I've welded Al, stainless steel, and cast iron with OA, so I'd take that first answer with a large grain of salt. A torch can also braze, silver solder, cut, and heat, so it's good to have.
  14. #10
    Jun 2012
    Michigan
    4,509
    4108
    2668
    Quote Originally Posted by fciron View Post
    He's asking the same question that is on his school test. Word for word.
  15. #11
    Jan 2006
    Angier, North Carolina
    2,559
    1033
    938
    In general, not much of anything can be welded by gas ... you'll need a flame.
    But if you mean welding with an O/A torch: in addition to wood (mentioned above), plastics are pretty hard to weld without sending it all up in flame.
  16. Likes Kenre liked this post
  17. #12
    May 2017
    FINLAND
    1,598
    456
    736
    Tungsten carbide, Magnesium, Titanium, Sodium... Uranium, Plutonium and Radium are also probably bad news generally.
  18. #13
    Feb 2007
    St. George, Utah
    802
    346
    501
    Quote Originally Posted by memphisjed View Post
    stainless, ti, al, high zinc brass. . .
    In A&P school, 1976, I watched my instructor weld up a 1/2" long crack in an aluminum aircraft intake manifold with OA gear. It was amazing. Nothing happened.... and then with a flick of his wrist a single ripple-less bead went the length of that crack, inside height nearly identical to the outside. That manifold went back into service.
    That was the powerplant instructor. The welding instructor at that school had a contract with Boeing to hand-weld tiny stainless beads on solenoid end-caps after coils were in place, part was for the B-52. Beads were less than 1/16" wide.
  19. Likes sfriedberg liked this post
  20. #14
    May 2017
    Minnesota
    858
    955
    510
    Don't forget carbon fiber, fiberglass, and ceramics.
  21. #15
    Dec 2012
    Se Ma USA
    1,444
    110
    815
    You guyzs forgot unobtainium. Flux capacitor needed w/o gas.
  22. #16
    Jan 2019
    Tennessee
    405
    123
    109
    how did you get stainless to flow? I have had the seams repel from each other? Forge welding works, then you get iron oxide to act as flux.
  23. #17
    Jan 2019
    Tennessee
    405
    123
    109
    ceramics, you can get the glaze to flow with care.
  24. #18
    Jun 2016
    New York
    1,386
    719
    584
    Are you asking about Oxy-fuel? Do you have any reference books for your course? It’s not like this hasn’t been part of standard instruction on welding for the last 60 + years..
  25. #19
    Oct 2010
    Oregon
    5,009
    4170
    1809
    As everyone has guessed, odds are good this was a homework question. If not, I'd wager a nickel he's got a garage bet with another non-weldor about "the best" welding outfit.
  26. #20
    Jul 2019
    13
    Thanks for sharing the useful reply.
