Which Material Cannot be welded by gas? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21
    Oct 2009
    Louisville, KY, USA
    920
    213
    203
    Quote Originally Posted by memphisjed View Post
    how did you get stainless to flow? I have had the seams repel from each other? Forge welding works, then you get iron oxide to act as flux.
    I don't really remember. I'll have to try it and see.
  2. #22
    Aug 2011
    new plymouth id
    359
    25
    88
    a couple of pieces of 1.5" plate would love to watch some poor sucker trying to do that with gas
  3. #23
    Dec 2012
    AUSTRALIA
    1,787
    8
    541
    Actually ,you can weld magnesium with oxy acetylene....any old car book will tell how,as many old car castings were magnesium(10% Al).....did you know AEC used magnesium in sumps ,blocks and housings up to the mid fifties?...Early VW motors also used magnesium castings.........when you get an AEC 7 .7 block ,the difference in weight from say a Gardner 6LW block is very noticeable......And despite what you might think,its not all that easy to set a magnesium casting to burn......Ive tried on AEC flywheel housings that were cracked.....the first one I did ,I ruined it by using Al filler rod.....Fairly common mistake.
  4. #24
    Nov 2003
    Beaumont, TX, USA
    4,860
    168
    1471
    Gas will weld almost nothing. It is the heat of the flame when the gas is burned that allows welding.
  5. Likes awake liked this post
