I need to build a batch of Din studs to mount small small chucks on the lathe. I would buy them but none in stock anywhere. Could one use mild steel for these or does it need to be something stronger like 4140 or the like? The reason I am favoring the mild steel is I have lots of material in that size and its easy to machine. If I was to go 4140 I would have to turn down larger bar stock. The chuck is a 6" and there are four studs holding the backing plate onto the taper. Thanks for any insights in advance.
