Monarchist,
Your posts I`ve read sofar showing vast knowledge and I`m just an amateur in machining so I`m basically wrong here and do not dare to ask too many silly questions.
Amestra (France) was bought out by SRW (Germany) and that quote I found is dated 2012 posted by a french reader in a french forum. The production facilities in France were closed in 2013. So it was Amestra-France I guess .
Yea I have the spindle in front of me but I`m not absolutely sure wether it is correct what I`m reading because the bed of my CAZ is a tad worn.
An old catalogue from Amestra showing Cazeneuve-HBY and Cazeneuve-HB Chucks and (steel-)faceplates to be of the same size.
This is what I found in a french forum:
Bonjour,
La conicité est une variation de diamètre pour un déplacement de 100
le nez de broche Cazeneuve est donc de type morse.
Celui de l’HBY 590 est spécifié sur un de ses plans : 5 % demi angle de 1.432 °
post #100
connaissez vous les "japan cazeneuve"?? | Page 7 | Usinages
Internet-translator:
The taper is a variation in diameter for a displacement of 100
the nose Cazeneuve is therefore Morse type.
That of the HBY 590 is specified on one of his plans: 5% half angle of 1.432 °
Cause I am an amateur I can`t figure what he`s saying although I have the MT-Taper chart in front of me. I`m playing with the numbers but I never ever get these numbers mentioned by that french guy.
So, whom am I supposed to trust ?
My readings (bed worn) or those numbers mentioned in the post which I can`t figure out, yet?
rainer
The translation is correct. Not that common in "our world", but angles CAN be expressed as percentages, either of 360 degrees, or as a tangent - run-rise vs run-length.
That said, I don't get 5% (1 part in 20) to match-up with either the 1.432 degree "half angle" (degrees one side departs from the axis of rotation), or a 2.864 degree full-angle degrees one side holds to its opposite side of the nose taper, or the backplate cavity for it.
As to the reference to MT? The INTERNAL spindle taper is such, but I don't grok the "MT" relationship to the external taper. It is way larger than max MT, even if it "coincidentally" matches one of the several MT angles.
FWIW-not-much-dept, the Jarno taper is regular, all sizes, has no theoretical upper or lower size bound. MT & B&S are NOT regular, all sizes and DO have practical bounds.
BFD.
We shall just have to measure what we have, do trial fits, adjust, blue-up to prove, then PUBLISH.
I have ONE Cazeneuve HBX-360-BC in rather decent condition - the one Milacron was holding. It came with TWO backplates.
One is fitted to holding a rather useful Jacobs RubberFlex 900 series master chuck, one collet. "Useful" as I have another for the 10EE's, plus somewhere around 3 sets of collets and "butt plugs".
The other held a doubly-useless French "Handy" 200 mm / ~ 8" 3-Jaw chuck, two-piece jaws. "Doubly" useless because in addition to being a "what WERE they thinking?" 3-Jaw, it was also too large to clear the sliding cover or even the cross-slide leading edge if asked to grip stock much over 2" diameter.
Regardless.. that's three surfaces with the Cazanenuve proprietary taper, one that I can get a proper 4-jaw (Swedish made "SCA" brand ) 7 1/4" chuck onto.
Even so, my plan is to fab the new backplates
on the 10EE so I can detach @ D1-3, still in 4-jaw, to "proof" them at progressive intervals against the HBX spindle, try again, etc. w/o need of fabbing - and "proving" - a "dummy" spindle nose.
That said ..if you have another lathe, please "beat me to it".
Having been so foolish as to trip whilst backpeddling behind a meant to be
walk-behind, AND NOT meant to be
fall-down-behind Toro "Dingo" tracked mini-front-end-loader, and run the overly-cooperative little b***h over my feet and legs clear to the crotch just over two weeks ago, it may be "a while yet" before I am functional in the shop.
