Material for english wheel anvils
Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Feb 2020
    CANADA
    Alberta
    5
    Default Material for english wheel anvils
    Iím currently in the middle of building an English wheel from scratch. I am ready to build the lower anvils for the machine, and need to select the correct type of steel.
    I would like to machine the anvils, then have them heat treated and hardened by a shop herd in town.. This will allow me to run the anvils over mig welds without damaging the anvils and nicking them.
    My steel supplier has mild 1018 cold rolled bar. Can this be machined and hardened easily?
    If not, what do you suggest I use l for steel, that isnít a pain to machine on my small lathe, and can easily be hardened after machining?
    Jan 2002
    Upstate NY -In the Flats next to the corn fields
    9,484
    1791
    2747
    You're asking for everything but you're not going to get it. Pick one, easily machined on a small lathe, or easy to harden. Low carbon steel can be case hardened, and high carbon steel can be hardened with fewer steps, but machining it on a 'small lathe' might not be much fun. Then you need to specify how hard you want the pieces.
  3. Likes Ray Behner liked this post
    Mar 2009
    Brunswick Oh USA
    4,749
    5582
    2887
    There's a heap of companies out there that sell all sorts of EW dies.....cheap
  5. Likes Gordon Heaton, TheOldCar, dkmc liked this post
  6. #4
    Feb 2007
    St. George, Utah
    1,292
    836
    875
    1018 will not harden without added carbon, as in case-hardening mentioned by dkmc above. Depending on how small your lathe is, you can cut O-1 and 4140 if you are patient. O-1 is about the easiest to harden and is probably cheaper than 4XXX steel in most areas. You need to have a good finish on your part if you don't intend to grind after hardening. A pro heat-treat shop can use a vacuum furnace or other means to yield a pretty good finish if they had one to start with. Any flaw in your parts will be embossed into your work.
  7. Likes Ray Behner liked this post
  8. #5
    Aug 2004
    Virginia
    2,823
    228
    1262
    You can't make them and get them heat treated for what you can buy them for.
  9. #6
    Feb 2020
    CANADA
    Alberta
    5
    I actually didmít know that you could get a set for under 200 bucks.
    If it comes to it, I will just machine them out of 1018. It all depends on how much it is going yo cost to get a set shipped up here.
    Anyone have any other sets they would recommend? Iím aware of Hoosierís, but they are out of my price range currently.
  10. #7
    Mar 2009
    Brunswick Oh USA
    4,749
    5582
    2887
    Quote Originally Posted by Smi_tty View Post
    I actually didm’t know that you could get a set for under 200 bucks.
    Anyone have any other sets they would recommend? I’m aware of Hoosier’s, but they are out of my price range currently.
    search english wheel dies.
  11. #8
    Jul 2007
    Missoula Mt
    1,357
    58
    635
    Use 8620, or 4130...4140...Phil
  12. #9
    Aug 2007
    Idaho
    2,472
    1044
    1322
    This is a better forum for these questions, there are folks working on projects like yours there every day.
    All MetalShaping - Powered by vBulletin
  13. Likes TheOldCar, bsg liked this post
  14. #10
    Jun 2008
    Burbank, CA
    365
    113
    71
    Just thinking out loud but how about Stressproof (1144) ?
    Easy to machine, and no heat treat needed. Or how about 4142 ?
    Chuck
    Burbank, CA
  15. #11
    Aug 2007
    Idaho
    2,472
    1044
    1322
    If he wants to run over welds they likely should be pretty hard and not just on the surface.
    I see he is over on the all metal shaping forum too.
  16. #12
    Jan 2002
    9,484
    1791
    2747
    I had no idea a complete set was that cheap......wow.
    Quote Originally Posted by crossthread View Post
  17. #13
    Jul 2006
    Hillsboro, New Hampshire
    12,950
    2938
    8932
    If the OP wants to run over MIG beads (E70S or similar?) without damage, he's going to need anvils in the mid-high 50's hardness range. If the Jegs are hardened, it might be only 4140PH level (no more than 30's), and those I'd bet would mark up pretty soon.
    My opinion, of course. If others have done this and it's NBD, I'd like to hear it.
  18. Likes kustomizer, Gordon Heaton, Ray Behner liked this post
  19. #14
    Aug 2007
    Idaho
    2,472
    1044
    1322
    I have 2 dozen anvils for mine and only a few that I run on anything other than new smooth sheet, but like any tool, you have some bits for hard rough stuff and others for shiny new, after those welds are worked a bit you can use the good ones.
  20. Likes Milland liked this post
  21. #15
    Jan 2016
    New York
    295
    6
    81
    Default Steel selection for bottom rolls
    Quote Originally Posted by Ray Behner View Post
    Your receiving expert advice and seem to be rejecting the advice. SAE1018 is not the material for this job if you would like good tools. You will not be happy with the long term results of the tooling. It has been suggested using O1 tool steel. Purchasing the bottom wheels seems to be your best choice unless you want to do the job yourself for a learning experience.
    Roger
  22. Likes Gordon Heaton, kustomizer liked this post
  23. #16
    Aug 2007
    Idaho
    2,472
    1044
    1322
    I am a firm believer in doing a thing simply because you want to and you don't have to justify it to anyone, however doing something just to be cheap and easy is a whole nuther thing.
  24. Likes dkmc, TeachMePlease, richard newman liked this post
  25. #17
    Feb 2020
    CANADA
    Alberta
    5
    Iím all for learning new things, and building stuff. I will check with my steel supplier tomorrow and see what else he can get a hold of for me.
    Thank you all for the great responses and info.
  26. #18
    Feb 2010
    ch
    3,230
    271
    448
    i would talk to your heat treater. he will know what to use thats available and maybe point you to some leftovers locally.
  27. #19
    Oct 2005
    21,576
    I’m currently in the middle of building an English wheel from scratch. I am ready to build the lower anvils for the machine, and need to select the correct type of steel.
    If not, what do you suggest I use l for steel, that isn’t a pain to machine on my small lathe, and can easily be hardened after machining?
    Use "Track Rollers".....
  28. #20
    Jul 2006
    12,950
    2938
    8932
    I bet the right size cam follower bearing would work well, the outer race is thick enough you could get some decent curvatures on them before risking failure.
    Just would need a good lathe and CBN (or ceramic) tooling to cut them.
