Material for rock chipper teeth. - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21
    May 2006
    northwest ARK
    2,957
    4176
    404
    *See first sentence is original post. (Rock splitter).
  2. #22
    Oct 2005
    14,350
    Quote Originally Posted by jackal View Post
    Yes, but your title says "Chipper".....
  3. #23
    May 2006
    northwest ARK
    2,957
    4176
    404
    I guess it chips it until it splits. Lol
  4. #24
    May 2006
    northwest ARK
    2,957
    4176
    404
    It has about 20 of these teeth on top and bottom.
    They score a line and it breaks the large limestone flagstone into smaller pieces.
    Then they use them for walkways , walls, fireplaces, etc.
    The rocks are 3-5" thick.
  5. #25
    Jan 2014
    Houston, USA
    361
    1056
    237
    Splitter... so these teeth are just pressed down on the rock causing it to split in a straight line. No impact, just pressure, and in limestone to boot. I would use a easily machined steel and just harden the work edge. Re-machine as a set and harden again after wear. A picture of the machine would help.
  6. Likes digger doug liked this post
  7. #26
    Jan 2012
    Bayonet Point
    156
    141
    60
    Hardfacing Alloys
    I have fabricated teeth similar to those out of 4140. I overlayed working edge with excellent results and most of time can re weld teeth
    on machine to rebuild worn surfaces'
    If you call the company they will recommend a rod/wire that will perform as you require that is hi impact/high abrasion etc.
  8. #27
    Jan 2016
    New York
    211
    60
    Default Steel selection
    I'm working in some parts for a rock splitter.
    The teeth have a slot and some grooves for mounting.
    The machined part is hard but a file will barely gouge the corner.
    The tips that cut are glass hard.
    Any suggestions to what material these are?
    The dimension are 2" wide and 1" thick by 6" long.
    I'll try to get a pic.
    I'm hoping it is something that I can oil harden .
    I would go with D2. It oil hardening and can be tempered to 62 to 64 Rc. Good wear qualities and is easily available. If your looking for a shock resistance tool steel consider S7. It is also oil hardening will temper to 60 to 62 Rc.
    Roger
  9. #28
    May 2006
    northwest ARK
    2,957
    4176
    404
    I'll get some pics of the other parts.These are stacked side by side and sandwiched between (2) 3/4" plates.
    The 3/4 plates are 1 foot 2 foot.
    Thanks for all of the input so far.
  10. #29
    Oct 2005
    14,350
    Is the customer going to agree paying for a more exotic material such as D-2
    along with the increased machining cost's ?
    Over the above mentioned 4140 ?
  11. #30
    Mar 2005
    Clev, OH
    283
    49
    83
    Quote Originally Posted by rbdjr59 View Post
    I almost agree - use pre-hardened stock at HRC 28/32 and flame/induction harden the tip to HRC 49/53.
  12. #31
    May 2006
    northwest ARK
    2,957
    4176
    404
    This customer won't mind paying for something of quality and durability. I really dont think they'll pay for D-2.
    Probably the 4140 and heat- treat, and possible hard surfacing the tips.
