I'm making (designing) some bearing cups to hold bearings that will press into aluminum housing (bearing presses into cup and then bearing cup assembly presses into aluminum hole). I could use some recommendations on material selection for the bearing cups.
Goals: 1. prevent aluminum galling, good machinability/low cost, corrosion resistance is desired but not necessary
So far I am considering 4130 (will rust but the cost is lower than SS), 304SS, 416SS, or 7075-T6 type III anodized.
Any input would be greatly appreciated!
