I need to replace a cracking and delaminated touch pad cover for a flat seamless plastic electronic control. There are metal, slightly raised "bubbles" underneath that actually are the contacts so this is just cosmetic and to keep dirt out. Ideally this would be some sort of transparent self adhesive relatively flexible but durable material. I can remove whats on there, make legends for each "button" contact, stick the legends under this clear adhesive material in the correct spots, then stick the sheet over the entire control panel face. Is there such a material? Some sort of industrial quality clear contact paper?
