revrnd
- Jan 17, 2013
- Apsley, Ontario
I've been using some hammer faces (that are described hard white nylon) on some specialty hammers. A couple of users have reported that the nylon isn't standing up to their use, (chipping ice and snow from snowmobile track suspensions). It's not the ice, that's causing the damage but the edges on the parts.
I've made a pair out of Delrin for one of the folks to test. I'm only using Delrin as a test, since I have some on hand. I'm not sure if Delrin is a better or worse substitute material for the nylon.
So now my question, can anyone suggest a readily available 'plastic' that won't gouge in use or fracture
in the cold (below freezing temps)?
TIA
TIA
