Max depth of cut vs. tool post size
Results 1 to 17 of 17
    Dec 2018
    Indiana
    53
    Default Max depth of cut vs. tool post size
    Currently have an A size Dorian quadra tool post and looking to change to a multifix style. Cant decide on size whether to stay with the A size or move up to E size.
    Can take a .085" deep of cut in A36 2" diameter anymore and I start getting chatter. I don't think the tool post is holding me up but not sure if the A size would hold up to much more. I know there are 40+ variables involved which have nothing to do with what size tool post is but I still think size plays a role.
    Would like to stay at the A size if possible because of the extra room but don't want to leave anything on the table in terms of rigidity. Both A and E will use the same size mounting stud and tool size. As for my application either size will fit fine.
    Anyone want to take a shot at giving a general max depth of cut for each tool post size in mild steel?
    Eg.. Aa max .040
    A max .120
    E max .200
    B max.....
    Any input would be welcomed.
    Aug 2015
    Illinois
    1,256
    895
    526
    I think the rigidity of the lathe components will have a greater effect than the toolpost size.
    If you select too large a toolpost you might not be able to get the tool on center.
  3. Likes Red James liked this post
    Nov 2002
    St.Louis, Missouri, USA
    2,070
    121
    466
    Maximum material removal seems to be more about HP and mass of the machine than anything else so theoretically a more massive tool post would help.
    One thing I don't like about any of the quick change posts is the amount they move the cutter off the center of the compound and to a degree the cross slide. Years ago a fellow whom I considered quite knowledgeable said the carriage on LeBlond lathes wore faster on the head stock side of the ways. I looked and noticed as a lot of modern lathes that the wings were shorter on that side so it made sense. On the same subject it seems like placing the cutting tool farther in that direction could add to that situation?
    I have no test results for a base line but don't feel like you will gain anything having a tool post that is too big for a given lathe. As was stated already there might be issues trying to get the tools on center.
    Dan
  5. Likes Illinoyance, Toolmaker51 liked this post
  6. #4
    May 2017
    FINLAND
    1,505
    432
    692
    Quote Originally Posted by Danny VanVoorn View Post
    Multifix actually gives horsepower recommendations for their holders if I don't remember wrong.
    To OP: go for the biggest one that still allows you to get the tools to center.
    B-size multifix:
  7. Likes Sachmanram liked this post
  8. #5
    Jul 2007
    UNITED KINGDOM
    4,493
    2293
    2085
    I was running 0.150" DOC with an A size 2090 post and holder in cast iron yesterday on an HLV if that helps any. No problems at all.
  9. #6
    Jan 2007
    Norfolk, UK
    17,913
    13489
    13352
    What lathe is this on?
  10. #7
    Dec 2018
    Indiana
    53
    Thanks for all the replies.
    Mark that is great info and helps a lot knowing they can take that deep of cut. Like I said before I like smaller for the extra room. Can fit a B size but if no benefit it’s just wasted space from what I gather.
    I hate the hp rating on them. 1hp can be 20hp cutting with the right gearing and 5hp can turn into 1hp.
    Thanks again.
  11. #8
    May 2017
    FINLAND
    1,505
    432
    692
    Quote Originally Posted by turnworks View Post
    Thanks again.
    Boring bars would be one reason to go for the biggest one that fits&sits comfortably to your lathe.
    I have boring bars up to 20mm for small hobby shopping, anything bigger needs bit of extra work.
    edit: dunno what I was thinking on earlier post, I have A-size holder for max 20mm tools. B would be lot bigger.
  12. #9
    Dec 2015
    Connecticut
    557
    22
    146
    B size will go 40mm
  13. #10
    Aug 2008
    near Cleveland
    793
    49
    101
    Try turning the tool upside down and run the lathe in reverse. If that cures the chatter, you likely have either wear problems or loose gibs.
  14. #11
    Jan 2002
    West Coast, USA
    7,293
    435
    4761
    . . . I hate the hp rating on them. 1hp can be 20hp cutting with the right gearing . . .
    Wish that were true . . .
  15. #12
    Jan 2009
    Missouri
    83
    122
    22
    Quote Originally Posted by MattiJ View Post
    B-size multifix:
    Image makes a statement...some call it "Proof of Concept"
    While mass and width of carriage are certain factors, toolposts are the weak link; not only their width or lack thereof, but position ABOVE the sliding surfaces, exerting additional leverage.
    Widths of locating registers and cutter position from same is why so few examples of KDK are seen on sizeable equipment, MultiFix and Aloris patterns address that, but none more so than Dickson type.
    Even the Enco copy, bigger machines awash with them.
    Must be reasons. a] Journeyman or Master ordered tooling for new or existing lathes. b] Deskbound buyers didn't.
  16. #13
    Jan 2002
    West Coast, USA
    7,293
    435
    4761
    Quote Originally Posted by Toolmaker51 View Post
    . . . While mass and width of carriage are certain factors, toolposts are the weak link; not only their width or lack thereof, but position ABOVE the sliding surfaces, exerting additional leverage. . .
    A larger toolpost actually increases the offset and leverage factor in most every type. So while they are slightly more immune to deflection, they actually exert a greater moment on everything below.
    Where they might shine is with larger tools, especially if overhung, such as boring bars and cut-off tools. If the OP is going to keep most of his cutting tools (say, 1/2" size), then I'd suggest there won't be much difference in rigidity. If he's going to move up in size on everything, then there's the difference.
    Just considering bending moments, a 1/2" square or round tool vs. a 3/4" square or round tool is going to be more the controlling factor in deflection than something like a 2" square toolpost vs. a 3" square toolpost.
    My experience is that the three sliding/gibbed axes are where most slop occurs and tightening those up, changing or damping the forcing frequency, and using positive tool geometry are the best ways to reduce chatter (beyond buying a precise and massive lathe in the first place).
  17. Likes Illinoyance liked this post
  18. #14
    Dec 2018
    Indiana
    53
    Quote Originally Posted by PeteM View Post
    My bad should have said torque not hp but I think the point was valid.
  19. #15
    Jul 2006
    Australia (Hobart)
    3,302
    514
    2501
    Agree. I re-scraped the compound & rotating ring base to very good alignment/bearing and did a half-arsed job on the cross slide because I didn't have the time/energy to do the saddle. This made an *enormous* difference in chatter, it's vastly reduced.
    Previously you could see the tool deflect in/out of an interrupted cut and it was horrible.
    One tip for life - never buy a used lathe that came out of a welding shop.....
    PDW
  20. #16
    Jul 2004
    Houston, TX USA
    28,860
    104 years ago they just did it - with HSS by the way. Those are non wimp chips forming the border of the page.
    I have to suppose the lantern tool post shown was used
    I would imagine from the mass of the chips that at least .060 IPR feed was in use
  21. #17
    Apr 2018
    CANADA
    British Columbia
    60
    22
    7
    what is your top of compound to center height?
