Measuring hydraulic pull-back ram force
manoweb
Sep 13, 2018
An engineer asked to perform some rough testing on 6061 Aluminum parts I'm fabricating. The setup should be relatively simple, I have to pull this part apart and see how much force it takes to deform it and make it fail. My idea is to fabricate a rig with steel tubing and use a porta-power pull-back ram while filming the process from a couple of different angles, and measuring the pressure with a good quality digital gauge. This should make it easy to calculate the force applied at any given time. However this assumes I know very well the size of the hydraulic piston. This is a pull-back ram and it might be more complicated than just measuring a diameter. I have placed an order for one of these rams and it's going to take a couple of days before I get it.
Anybody has any advice on what I am getting into with this? :D
Any advice? Thanks!
I think it's a long shot to be able to get in touch with somebody that knows what I am even asking and is willing/authorized to help a random customer. Nowadays whoever sells this stuff does not even know what it is...
If you purchased from Enerpac/OTC/Simplex I would expect an answer.
Using a hollow cylinder for tensioning application is popular, and they need
that information just like you doo.
I would suggest putting a dynamometer inline and then there’s no question as to what force you’re exerting is.
Be safe
Jeremy
Edited because of stupid fingers
Eheh we are taking a "scrappy" approach here, this is possibly a one-off test and I'll have to do with much cheaper equipment.
You got any kind of load cell?, I’d be tempted to ring a local college with Engineering department, usually helpful, they probably have the latest all singing instronic tensile test machine sitting idle in case the sound of the sample breaking offends some minority group
You can fabricobble just about anything but trying to derive the force from the hydraulic pressure is always going to be troublesome, use the hydraulic to pull or push the load cell is easier, failing that stick on bridge strain gauges are cheap disposable parts, clean, stick and measure, any NDT firm could help
Mark
I don't know how much force you are talking about, but if it is a "few" off, Amazon sells a crane scale that goes up to 1000Kg for $140. A section of I-beam with a couple of lugs and a come-along would complete the tester. A 300Kg scale is under $35.
is it being tested to deform or to fail? that is a big difference it will start deforming before you can see it but most of those cylinders can be taken apart fairly easily and measured. I used a 4" cylinder filled with oil and pressure gauge with eyes on both ends for a juryrigged pull scale on a drill rig casing line so I knew my tonage that was hanging
All thats needed is to know the effective area of the cylinder......any brand name cylinder will have this information readily available .....if its a Chinese cheapie,the pull the ram to pieces and measure and calculate the effective area....then you need a pressure gauge....Force is pressure by area...simple.
OP says a scrappy approach for a one off......but hollow rams dont come cheap ,so some other approach is needed.....maybe make up a fixture so the loading can be done in the shop hydraulic press.
Pressure gage in line on the pressure side of the ram works just fine. Your force is area of the bore minus the rod area and multiply that times your pressure, should get you within ~5 percent.
Frame can be stupid simple, enough steel to not be a concern and away you go.
Crane scale load cells and readouts can be found reasonably priced on eBay if you want a readout. Just having a load cell doesn't do anything for you unless you have a readout and a way to calibrate it. Used dynamometers can be found too, for reasonably priced, but unless you have a way to check it, you don't know if it's accurate.
If you are asking this question, don't even worry about trying to use strain gages by themselves.
Fixturing is always the biggest PITA on doing small testing like this. If you've got a university with an engineering program nearby and you can already fixture it so it is either a straight pull or push, they might just do it for free. Pretty easy to get more time in fixturing than testing.
If you want an actual report, those cost money.
Problem with bourdon pressure gauges unless dead weight pressure test rig handy they are as much use as a chocolate saucepan, due to the linkage not even linear, you can tweak the things to get a straight bit around the pressure your at but most of them are wildly inaccurate unless you stump for certification and calibrated.
Electronic pressure gauges may be better I suppose
Mark
Ahhaah that was unexpected and so even funnier
Yeah in theory - any other time in history I could ask at least two colleges with very well equipped labs. But during the coronavirus, it's all sealed up and closed, ont even the actual students get to use the equipment. I tried.
Mark
You are right, my bad I should have given some more details. It's a hexagonal connector made out of 1/4" 6061. The computer simulations say it should take few tens of kN before it fails (that is, few tons). I'm going to use a 10ton pull-back ram.
We are going in all the way :) and deformation, cracks, rupture, are going to be filmed but we need to have an indicator of how much force we need to apply. What you are describing does not sound that different to what I was thinking.
Yes the shop press could be used to do this, with a fixture to create tension, not a bad idea!
Mark
Yeah nowadays it's easy to get digital pressure gauges that go up to 10000PSI and some even have USB output to capture with the computer, but the video will be sufficient.
That part is clear.
Exactly, a little bit of band saw and welding and it should be done quick.
OK now you made me curious, now I'll check this out, I'm never shy to pull out the oscilloscope
Unfortunately - Colleges are off limits right now. Even students cannot access the labs.
I got word from the Engineer it will take several more days for the design to be ready to manufacture. In the meanwhile I'll try to come up with something, thanks to everybody for the ideas!
