Measuring an odd thread N 05-32
Results 1 to 7 of 7
    Aug 2006
    greensboro,northcarolina
    2,643
    182
    713
    Default Measuring an odd thread N 05-32
    I've never seen this and I've been doing this a while (49 years). Print says N 05-32 25mm by 32 TPI. It's not in any standard I can find. Working back through purchasing who has requested it to try to get to engineering is taking a while. I'm trying to come up with a 3 wire calculation, but would really like a mating part or a gage. Not sure that is available. It's an external thread in 17-4 stainless. Anybody dealt with this before?
    Sep 2009
    Virginia
    152
    30
    21
    I think what you have there is a bearing locknut
  3. Likes Bobw, Illinoyance liked this post
    Sep 2009
    Virginia
    152
    30
    21
    look up mcmaster carr # 6343k16,I had a part that used those to hold a 25mm bearing
    Aug 2006
    2,643
    182
    713
    That's close, but 25mm is .984 not .969
    Sep 2006
    SW Wisconsin
    769
    261
    290
    Quote Originally Posted by RJT View Post
    No, it is not. 0.969 is clearance on 25mm for the 32TPI thread.
    An N-05 nut goes for a X05 series bearing and uses a W-05 star washer to keep it tight.
    People lucky enough to be in a Metric World have their own series of bearing locknuts and washers.
    Ed.
  7. Likes Doozer liked this post
  8. #6
    Aug 2006
    2,643
    182
    713
    Ed,
    How can .968 be clearance for .984 major diameter? This is a male 25 mm thread.
    Sent from my moto z3 using Tapatalk
  9. #7
    Sep 2006
    SW Wisconsin
    769
    261
    290
    Ed,
    No, it is an AFBMA standard locknut Series N-00. Thread major dia for an N-05 is .969 and 32 TPI.
    The thread is under 25mm to allow the bearing to pass over and the nut is used to retain the bearing.
    If it was a true 25mm locknut thread it would be 1.5mm pitch not 32TPI.
    As others have said, go to mcmaster.com and search for bearing lock nut.
    Ed.
  10. Likes boomerang69 liked this post
