i turned a cylindrical part and measured runout in the chuck using a 1µ mitutoyo with a large radius tip and turning chuck by hand. i saw 1-2µ. great. then i measured it with spindle running at 25 rpm. 11µ. hm. thinking vibrations. disengaged the gear and let the machine run. no movement. turned spindle by hand and got 1-2µ again. got a 2µ graduated test indicator with a 3 mm tip and it shows 12µ.
1. whats happening? do fine vibrations transmitted to the mitutoyo make it show correctly by eliminating hysteresis?
2. guessing that 11-12µ was what it actually is i tried adjusting the plain bearings wihout any success (turned another piece). how bad do you thing this is? (lathe has 370 mmm swing.)
