Measuring Tapers with Combination Square
Results 1 to 7 of 7
    May 2017
    Missouri
    7
    Default Measuring Tapers with Combination Square
    On Instagram (@grungymachinist), I share tool tips from old machinist books in my personal library every Thursday among the old machinery pictures I typically share. Today I posted the following tool tip on measuring tapers with a combination square, and I was surprised by the reaction it received. So I thought many people on here would find this tip useful as well.
    I'm interested to hear if you have ever heard of this technique before, or if this is news to you.
    Grungymachinst
    Grungy Machinist (@grungymachinist) • Instagram photos and videos
    Jul 2004
    Houston, TX USA
    29,487
    Good luck in determining the difference between Morse and Jarno. (2.974 degrees and 2.864 degrees)
  3. Likes lucky7 liked this post
    Dec 2005
    New Jersey
    3,939
    283
    485
    That looks like a poor way to check tapers. Hows this, put a 5" sine plate on the surface plate, place gage block of correct size for desired angle, place work on since plate, using height gage measure across top of work, should be same end to end.
    Nov 2003
    Beaumont, TX, USA
    4,907
    171
    1492
    Yes, the protractor head for the square is not accurate to better than about 1/4 or 1/5 degree. I have two of them, a B&S and a Starrett and neither of them will give you any better than that. This method will just leave you in doubt.
    Even with a Vernier scale that reads to 1/10th (6 minutes) or 1/12th (5 minutes) of a degree you are still going to be guessing.
    If you are measuring a taper, you need sine bar type techniques.
    Quote Originally Posted by johnoder View Post
    Sep 2010
    Oklahoma City, OK
    4,169
    719
    1758
    Horses for courses- this seems like a good spot check for....something?
    Apr 2006
    missouri
    217
    85
    58
    To use a sine bar you have to know what the angle is. If someone just walks up to you and hands you this part and says make one of these, you have no idea what this angle is, a guess (if you are really good) might get you within maybe 5 degrees. That’s a whole lot of trial and error in stacking gauge blocks. This method ought to easily get you within maybe 5 to 10 minutes. From there it’s a pretty easy adjustment to get the exact angle.
  8. Likes sfriedberg liked this post
  9. #7
    Sep 2010
    Oklahoma City, OK
    4,169
    719
    1758
    Quote Originally Posted by scraper View Post
    No. Mark two spots 1" apart, measure big end, measure small end, 2.5x (or whatever your sine bar dictates) that difference is your beginning gage stack. Dial it in, or use measuring tools, and calc your angle.
  10. Likes sfriedberg liked this post
