Metal building cost
Likes Likes:  0
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Oct 2006
    Woodland Hills, Ca. and some times Hutchinson, Ks.
    2,478
    20
    665
    Default Metal building cost
    We are looking at a piece of property in Hutchinson to build a shop on. The shop would be a small scale seed oil crushing plant. Preliminary estimates of 5-6000 feet under roof and one or more lean to overhangs.
    What is a realistic price for a metal building with a slab floor, nothing fancy.
    Steve
    Apr 2010
    Justin, Texas
    362
    104
    Here in north Texas, a 30'x40', 10' sidewall, 1 personel door and a 10' roll up door runs about 13K$ turnkey. Sidewall height, site challenges and options will make that number float.
    Dec 2000
    Bremerton WA USA
    10,718
    41
    4438
    Hard to say. Have you tried getting some local quotes? Got any tall equipment that needs vertical clearance? Extra height is an adder for any building. DO you need overhead crane service for maintentnce, etc? Electrical service? Plumbing and drainage?
    Can't just put up a building nowadays. Gotta cover all the bases. When the volume of paper equals the volume of the structure you're done and can move in.
    Oct 2006
    2,478
    20
    665
    Quote Originally Posted by Forrest Addy View Post
    Hrd to say. Have you tried getting some local quites? Got any tall equipment that needs vertical clearance? Crane service for maintentnce, etc. Electrical service? Plumbing and drainage?
    We have some requirements but, I want to get an idea of the basic shell. The height will be 16' at the eaves min. The slab would be 6" We don't have any crane speced; the materials will be transferred by auger, conveyor lines and, piping.
    Steve
    Jun 2010
    milton freewater oregon
    2,029
    3811
    1645
    My brother put up a shop thats 60' X 100" insulated . 8" floors. 3 big electrical doors , 10 windows and two man doors a bathroom and and small office, 3 30X30' concrete pads outside the big doors for $150,000. that was 15 years ago.
    That was cheap part, it was the 30,000 for septic system, water was $5,000 to hook up. the transformers on the power poles where $29,000. lighting was $10,000 to work good as a machine shop and not be dark like a dungeon. then the main electrical inside was crazy. All total it was $330,000 to open the doors and get to work. that includes 2 acres of land.
    Sep 2004
    Fort Worth, Texas
    2,267
    325
    210
    Quote Originally Posted by cvairwerks View Post
    cvariwerks, who did your building?
    Apr 2010
    Justin, Texas
    362
    104
    Rex: Haven't had one done yet, just noting what I see advertised in various papers and magazines. From what I can glean, they are doing weld up type installations, 4" slabs and no isulation.
    I'm looking at putitng up a 40'x60' with a 20' peak if I can get it through the variance process. We're limited to a % footprint of the building based on the backyard space. Mine works out to an oddball size, so we are going to ask to go a little larger to stay with standard pre-engineered sizes. It's a small town, so I don't anticipate any real problems as they have already indicated that it should be ok. I just need to get through some other stuff and we can pile the cash up for it pretty quick. I'm hoping to get it going this fall and be in it before the end of the year.
    Sep 2004
    Fort Worth, Texas
    2,267
    325
    210
    I must have talked to the same guy a few years ago.
    25x40 was $10K, all welded.
    Right now I just need a 25x40 4-car garage. Can't do metal here at the house (Keller area).
    May 2007
    nowhereville
    3,723
    79
    On that size, I would strongly urge wood if you are crafty or construction oriented. I also think a lot of people are afraid of DIY trusses. Usually can save 50% with DIY. can probably find some standard plans somewhere to get the county satisfied. Either way, wood will be cheap.
    Sep 2004
    Fort Worth, Texas
    2,267
    325
    210
    Quote Originally Posted by viper View Post
    I am not construction oriented, though I'd probably sub it myself. I'm in the county so no permits or code issues.
    I already have a 25x20 carport slab that i'd just double and build from there.
    All I lack is starting
  11. #11
    May 2007
    nowhereville
    3,723
    79
    Quote Originally Posted by Rex TX View Post
    I car port slab most likely does not have the concentrated load bearing ability due to lack of footings or stem wall. I certainly would not just build a building on a carport slab without knowing more about it. maybe if you poured it, you know the design. In calculating the weight, it gets up there quick. Need to be careful there.
  12. #12
    Sep 2004
    Fort Worth, Texas
    2,267
    325
    210
    I've had people look at it and they seemed to think it was thicker than most carport slabs. My concern would be tieing the two sections together. This site is on a hillside, so that's a consideration. At any rate, the carport slab will continue to be just for parking cars, with machine tools and cars on the addition.
  13. #13
    Nov 2002
    Cedar Park, TX
    78
    6
    On the metal buildings... call and confirm the sellers physical location, then drive by to see if they stock building materials. There are a lot of "low cost bidders" out there. Nothing more than a guy/gal with a computer. They are subcontracting everything with a third or fourth party. Huge nightmares.
    I used www.metalmarts.com in 2004.
    30' x 50' x 14' side walls, 4:1 roof pitch. FOUR DOORS 2 12' x 12' doors, 2 10' x 12'. $16K in 2004, $5K to erect it. Slab was full perimeter footing, 6" to 8" deep (machinery) and ran $12K then.
    A friend used Atlantic Building Systems: Steel Buildings and much more. and really liked working with them. (keep in mind that was in 2004)
    Lots of excellent ideas on Purdue's Ag Extension web site:
    AE-104
    Here in Texas, the 'thin insulation' with a reflective barrier is highly recommended. Helps keep the heat down (105F outside, 120F here in the shop at the moment.... ).
  14. #14
    Jul 2011
    Florida
    Quote Originally Posted by Steve in SoCal View Post
    Steve
    Be careful when you're shopping around; you get what you pay for. I got my degree in civil engineering/construction and boy did they stress ethics...because unfortunately in the construction industry is easier than most think to cut corners to save $ in both the design and construction phases.
    Anyways, MBMI Metal Buildings runs specials on several basic building designs that they have had their in-house engineers pre-design for each state based on each state's building codes & in Texas their 50x100x16 clearspan steel building is $32,201.
    50 x 100 x 16 Steel Building Special in Texas
    This building comes with comes pre-welded with a 40-yr warranty and they even have a 30-days delivery guarantee on most building. The only thing I don't think it includes is the footing, but most metal building companies don't. From what I can tell only very complex buildings are excluded because of the complex engineering design work they require...so I'd say the basic shop you are looking to create could be delivered in 30-days. Hope this helps. Keep us updated
  15. #15
    Jun 2006
    Kansas
    1,665
    331
    648
    I just got a quote on a new building. I am looking to build a #2 shop, equipment storage building. The building I priced was 50' x 80' x16' pole barn with a 20' x14' sliding door is 31,080$, add 6,120$ for insulation, add 2,485$ for overhead door. erected on site in Western Kansas. does not include concrete. I talked to my concrete buddy and he said 4$ square foot for 6" cement.
  16. #16
    Jan 2009
    CANADA
    Ontario
    85
    9
    I paid a lot for my new building, partly because it's all metal and insulated. I looked at pole barns, and would only have saved about 30%. I'm glad I chose all metal. It can't burn or rot or sag and has superior wind resistance and strength. Bugs can't eat it, and with quality insulated roll up doors and metal man doors rodents and bugs can't get in. You pay for what you get.
  17. #17
    Oct 2006
    2,478
    20
    665
    As mentioned in the title, pole barns etc are out. The last post sums up merits of metal. The only alternative construction we would consider is concrete and that is far more expensive. We are weighing the pros and cons of building out this site. There is a lot more than just a building and overhang.
    Steve
  18. #18
    Mar 2005
    Kansas
    8,685
    619
    4404
    Some places more than others, the tax man likes all steel much better than pole barns also.
  19. #19
    May 2008
    Gilmer, TX
    381
    120
    215
    This is what I did on my 40x60. Lots of work, lots of satisfaction when it's finished.
  20. #20
    Aug 2008
    Paso Robles, CA
    189
    72
    35
    My 5000 sq ft shop (50x100x16 eave) building built in California in 2007, was approximately $40k grading/foundation, $85k building/erection, and $5k for interior wiring. The building is nice, insulated, wall light panels, 2 electric roll-up doors, one manual roll-up, 3 man doors, 6 windows It has a 20x40' leanto extension of the roof on one corner. We had additional costs for exterior concrete flatwork, driveway, utility trenching for power, water and communication, and septic installation. We later built-out 1200 sq ft of office space including a restroom. My total cost was upwards of $300k. The basic building could have been usable for less than $150k.
