I'm working on a project which requires a couple of steel rods with threaded ends. The rods will be 3 feet long. The rod diameter will be 3/8". I would like to use the strongest (high yield strength) that I can and that I will be able to thread (DIE) with a hand held DIE and Handle. I've checked some web sites that describe the properties of different types of steel rods but I don't have any experience or frame of reference. The rods will be part of a wood working jig that will support a woodworking router in the center of the rods and should not flex.
Thank You for any advice and suggestions.
Also, I will need to get a DIE and Handle and would appreciate any advice on where to buy, brands, material, etc.
